4 kicker cvr's
do you think 4 kicker CVR 12s sealed with 1.5 cubes each with 250 RMS to each get pretty loud and low? thanks
mike
I am running two CVR's with a PPI PC2150 (600watts). We all know it is way underrated. It depends on the brand of wattage. If you are going to push them with a legacy 1000 watt amp, it isn't going to sound very good. However, if you run a JL1000.1 or PG tantrum 1200 for example, then yes it will play pretty loud. If it is loud you are going for, I would buy 2 15" subs that could maximize that kind of power.
I agree, 4 12s would be loud, but 2 15s would be a better use of your $. Also if you're going for loud you should really look into ported, just looking at the numbers 2 ported 12s would be as loud as 4 sealed 12s.
Post sales in the classifieds, with a piece of paper that has your username and date on one of the pictures of the equipment that you post...
52
Make sure when you get that headunit you turn off the useless blot features. I pretty much exclusively use Kenwood's cause of the user interface...
31
629
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
infinity1412
infinity1412
ocala fl
B_Master_Flash
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
