3 band parametric EQ
Taycron
Since my last post got an overwhelming zero responses I thought I'd try my luck again.
I'm looking at 2 head units (both kenwood because money got tight). One is a regular kenwood that has a bass, mid, and treble controls while the other is an excelon that has a 3 band equalizer.. Are they basically the same thing? I'm not really sure if a 3 band EQ is better or not..
On a Parametric EQ you can adjust the frequency that you increase or decrease the particular band at, (i.e. Bass, Mid, Treble)
same thing.
only difference is the the EQ tells you the frequency in hertz, while the other one just gives you generic names (bass, treble, etc).
HOwever, they may not be the same frequencies. Like it was said above, a parametric eq allows you to set the frequencies and width. I think on most radios 100hz is usually used for bass and about 10khz for treble
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
8
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
4
  • Locked
The Orion Concept 97.2 was the worlds first stand alone digital 30 band 2 channel equalizer. The Orion Concept 97.2 processes all the equalization...
Taycron
Taycron
Massachusetts
sumone
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
