Bigg Mike
CarAudio.com Newbie
I’m looking for someone who really knows the electrical/steering systems on a 2018 Dodge Charger SXT 3.6L.
I’m a basshead and have been upgrading the electrical system for my audio build. Before this issue happened, I had made the following electrical upgrades:
Then I had an electrical issue while the car was sitting at my wife’s work. Since then, I’ve been dealing with active EPS/steering codes, and the steering system needs to be recalibrated.
I can perform the calibration procedure myself, but I need to get the active codes cleared with a bidirectional scan tool before I can complete the calibration.
I’ve already gone through the recommended troubleshooting and fixes. At this point, I’m mainly looking for someone with an Autel, Foxwell, AlfaOBD, or similar bidirectional scanner who knows the 2018 Charger and can access the EPS/ABS modules, clear the active codes, and perform/initiate the required calibration.
I’m also specifically interested in hearing from anyone who has experience with lithium battery and upgraded electrical systems in an LD Charger, because I want to make sure I understand exactly what happened and whether any of the electrical upgrades could be related.
Any help from someone who has actually dealt with this would be greatly appreciated.
- Replaced the factory AGM 850 CCA battery with a Sriko 66Ah EVE lithium battery
- Completed the Big 4 upgrade
- Upgraded to 1/0 OFC power wiring
- Upgraded the fuse/distribution setup
