2 subs 2 mono amps load?
  • 2
chiguy
I am wiring (2) 4ohm subs to (2) 2ohm stable monobloc amps. The 2 amps are the exact same but non-strapable. so i will be using rca-y spliters. My question is im using a online calculator were you put in how many channel your amp is the lowest load for amp and the sub ohm with how many subs and it gives you a wiring diagram .My question is should i put in 1 sub with a monobloc amp or should i put in 2 subs and 2 channel amp to get my wiring diagram. Also would the y-spliter effect the ohm load. would i be able to wire it with one wire into the positive of 1 amp and the negitive into the other amp so each amp would only have 1 speaker wire acting like a 2 channel amp. thanks
There's nothing to get creative about here. You're just connecting a 4 ohm sub to a mono amp -- twice.
Y-cables to split the signal will work fine -- although a lot of amps have outputs to make it easy to go from one amp to the next w/o y's.
16
490
239
347
597
Look at the Alpine Type S subs.
19
chiguy
chiguy
chicago
n2audio
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
