2 or 3 MJs for this space!!!
illbmeubu
Rims older than he is...
Ok. So i have the opportunity to purchase up to 4 Mach 5 MJs (older model) for $100 shipped each:). I know I won't be getting 4 because I don't want a wall. But i'm thinking of either doing two or three. Here are the dimensions I have to work with (45"w*22"h*30"d: chevy tahoe). Can someone tell me if this will be enough space for 3 ported, or should I stick to 2. I may be a little flexible on the height. also, how many 4" ports would I need for this setup, tuning to 33Hz. I already have 4 aero ports waiting to be used. thanks.
I know I posted this in enclosure help, I just need a quick answer so I can get this transaction in motion.
thought about that, but don't know what kind of loss I would get as opposed to going ported with a fewer amount of subs.
dont know why you havent made up your mind yet. im guessing this is for spl only? these arent purpose made spl subs you know. but 3 or 4 sealed and your close to 50's if you do it right. its all testing man. we cant give you a definite answer for whats going to work.
This setup is definitely not for spl. I know these subs aren't meant for that. I just want some really good a nasty low end, potential groundpounder status. I'm gonna start with two, and see what we come up with.
If you can properly build to sealed suggested specs and fit it, since this is not for SPL, it would make the most sense. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I just bought two of them. plan to do from 11-12 cubes tuned to 32Hz. 29 is a little low for me. If that doesn't do the trick, then I'll get another and do something like 15 cubes.
illbmeubu
illbmeubu
Ohio
illbmeubu
