2 amps, 2 subs?? how do i do it??
78nova
XXX
i am going to get 2 xxx's and 2 hifonics bx1500d's and 2 batcaps, and I was thinking of running 1/0 gauge power wire from the battery to the distribution block and 4 gauge from the block to the batcaps and 4 gauge from the batcaps to the amps. And I was wondering if I'm gonna need anl fuses from the batcaps to the amps?
I will have ANL fuses on my setup but mainly just because I already had the fuse holders from previous setups. If your amp gets too much current technically it should blow the fuses on the amplifier. The ANL fuse on your power wire is usually meant to protect your car's electrical system, so as long as you have the fuse (I assume you'll be using a blade fuse on the 1/0 wire) on your main wire run from the battery like normal then you really should not have too much to worry about.
78nova
XXX
78nova
Bovina, Texas
PhatalOne
slater
    Mar 20, 2025
slater
    Mar 20, 2025
