2 Amplifiers wiring help!
0_over
Hi im all new in car audio installation.
CAR: Chevrolet Aveo 2004 Sedan
Here is system that i have to install:
SUBWOOFFERS:
2 x KENWOOD KFC-W3013PS 12" ( 400 watts RMS each - 4 Ohms )
Speakers:
ALPINE SPS-410 4" front ( Peak:280 watt per set RMS: 90 watt per set )
Alpine SPS-610C 6-1/2" rear ( Peak: 480 watts per pair / RMS: 160 watts per pair )
AMPS:
Kenwood KAC-9105D (1800 Watt Peak - 1200 Watt RMS Mono amp ) ----> subs
Kenwood KAC-2404S ( 4-channel — 40 watts RMS x 4 ) ----> speakers
DECK:
Kenwood Excelon KDC-X395
First of all, I would like to know if it's a good set.
Also, can you guys help my with the wiring? what are the cable kits i need for this 2 amps? i want know what cables i need and how approximately connect everything.
Thank you!
Ivan
It might be just as easy to run 1/0 to a distribution block and then run 4 gauge to the sub amp and 8 gauge to the speaker amp. That is an option or you could run a 4 gauge kit to the sub amp and an 8 gauge kit to the speaker amp
I like the dist block idea, as i do in all my vehicles as well.I agree on a 4ga wiring kit for the sub amp/supply to those two amps should be plenty big enough for powr supply, and 8ga for the stereo amp.0 ga kits for supply are expensive for what you have here, as you can get the 4ga, and be just fine,or even run a power supply of 2ga to the dist block, and add a fuse holder at the battery w at the least a 150 anl fuse holder.I think 0ga kit is overkill for these 2 amps.4 ga kit will be just fine.IMO
0_over
0_over
Canada
audiobaun
