2 Adire Audio Brahma's
If the amp can handle a .5 ohm load, then yes it will work. But there aren't that many amps that can handle that impedance. If you do this, yes the power would divide equally between the drivers. Whether they can handle that much power or not will depend on the enclosure used.
Steven Kephart
Adire Audio
I was told that the impedance of a Brahma is actually dual 1.4ohm. So a single one connected in parallel would give a .7ohm load...so then two would provide a .35ohm load. Any truth to this? Can you shed some light over here??
You guys are confusing nominal impedance and the DC Resistance. When under power, the lowest impedance the amplifier will ever see is 2 ohms. And that's what you have to worry about, the impedance.
Steven Kephart
Adire Audio
Wiseguy109
Wiseguy109
Grand Rapids, MI
Steven Kephart
RobGMN
    Apr 28, 2025
ThxOne
    Apr 28, 2025
