2 15"s in a F-150 single cab?
sportyrox
Hey Im about to buy some subs (namely 2 Rockford FOsgate Punch stage 3s) but i dont know if ill have any room in my truck. I am currently running a 9830 head unit with 4 Polk Audio DB570 speakers. Is there any way i can fit my 2 subs in my truck? Im hoping to fit them both in one box but whatever i can do.
I don't know the mounting depth on those particular subs but I doubt you'll fit 15's of any kind behind your seat. And if you do you will lose any leg room that you have
What year is the truck? I had a '92 reg cab and I tried lots of differant setups like 2 12's,2 10's and even 6 8's. The best I came up with was a single 10 Hcca and 1200 watts. You should look into a bada$s 10 give it lots of power and the biggest ported box you can fit
Yeah there is no way you will fit 15" subs back there. You can fit 12's if you have a custom box made but you will still lose a lot of leg room. The best thing to do is get 2-3 10" subs or one nice 12" sub with not a lot of mounting depth. I ran 3 10" RF HE's in a single cab truck for a year, they did fine, I was happy with them. The only way you will get 15" subs in that truck is to do a blowthrough like I did, and now I'm running 4 12" subs.
Its a 97 model, ididnt think it would fit,. Just sort of hoping . I think ill go with a couple of 10s powered by a good amp. What would be a good sub to get?
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
I wouldnt spend the funds on that amp if you have no way of knowing it works or not. Id purchase another 4 ch for that kind of money. You just...
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
I'm finally getting back into building a system after many years. I figure I'll document what I do. Here's my truck I initially wanted just a...
Has anyone bought/used a pre-fab underseat F150 SuperCrew sub box in a SUPER-CAB? 2015-2020 in particular I know the super crew seats are...
sportyrox
sportyrox
Ellijay,GA
sportyrox
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
