15" MTX Thunder6000 8 Ohm Problems
Electro16
17
Illinois
I only have one of these speakers, and I tried hooking it up to my home stereo but when i give the subwoofer more power it tends to make a cracking, popping noise. One person told me that it was that the subwoofer was getting too much raw current, is there any way to remedy this?
Oh, also, keep in mind that the sub is completely new, it hasn't been used very much at all and the sub is supposed to be for a car applications, but i figured since the sub was 8 ohms it would be fine on my home system, then again, it has been popping so I dont know.
I don't currently have it in an enclosure because i wanted to make sure the enclosure wasn't the problem. Also, I have tried to just send it low frequencies but some high frequencies are getting through. If you really believe that is the problem, how can I just give it low frequencies? Also, I do have an equalizer that i have tried to use to just send it the lows.
I'll try to connect it better, and I'm pretty sure it's not bottoming out, cause it isn't moving all that much. I think that in a box it would be better though. Well anyway, it seems that I have a few things i can try out. Thanks
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
989
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
3K
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
Electro16
Electro16
Illinois
Electro16
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
