1200W AMP
That PPI amp is the PPI2300 and i dont know if it is last years or not, but they are pretty expensive, your looking at around $1000, but look around and u may be able to find a deal.
That amp is 300 x 2 @ 4 ohm and 600 x 2 @ 2 ohm.
I have a PPI2350, it is a couple years old, but it puts out the power! 700 x 2 @ 2 ohms! but PPI are great and i would strongly recommend them.
hope this helps,
Dustin
MTX 8100d will put out 1500 watts at 14.4 volts 2 ohms. however, this amp has a serious current dram (100+ amps i think), meaning, if you got it, youd probably need a new alternator, depending on your car of course. you should be able to get one off ebay brand new for 350.
hope this helps
I would go with a PPI. they have a good reputation in general and i agree with that reputaion from hearing them first hand.
The MTX amp is overrated... it says that that the amp is 1500watts peak but thats rated @ 14 volts and there is no way to pull that from a car...
my reccomendations...
*Alpine MRV-1507 $455.00
*Hifonics Zeus $675.00
*RF POWER bd1500.1 $660.00
*Soundstream D'ARTAGNAN 5.1 $725.00 (this is rated @ 1,000 watts, but trust me it will push whatever you have)
*Harrison Labs AE-1600.1 $559.00
*MMATS D300HC $649.99
*Vibe 1200D Lanzar $249.99
later
Don't forget to mention the JBL powervalve 1200.1
Its rated- 600watts rms 12 to 14volts into a 4ohm load and 1200watts rms 12 to 14volts into a 2 or 1 ohm load. The jbl has a built in power regulator (like the JL amps) that allows it to function over a wide range of voltages and ohms.
Be sure to consider this amp before buying anything.
UNTOUCHABLEM3
UNTOUCHABLEM3
jbizzle
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
