1 or 2 amps?
BoneStockSystem
Oc,Ca
Is it better to power 2 subs with 2 seperate amps or juss one big one with the same amount of watttage from each amp or would 2 class D amps be better than 2 muti channel amps btw is it normal that amps can get really hot barely enough to touch for like less than 1 sec thx
you dont have to worry about setting the gains/crossover points incorrectly on seperate amps. and you dont have to wire 2 different amps.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
833
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
702
  • Locked
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
BoneStockSystem
BoneStockSystem
Oc,Ca
gxz
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
