1 Amp for 2 JL W7s?
cjjackson85
Banned
8,918
Idaho
Well, what I have now is 1 Rockford Fosgate bD1000.1 on each W7 (Slot-Ported to specifications) pushing 800 watts RMS or so. This setup is awesome, but I'm going to get another car in the near future where I can only have 1 sub amp. I have looked at the "1000+ Watt Amp" sticky ,but I want everyones recommendations on those & other amps to power my subs. Remember the W7s are SVC 3-ohm, so if they are wired together in a series it's a 1.5 Ohm load (1-Ohm stability is therefore a necessity). I DO NOT want the cheapest amp available. I DO want the best quality amp regardless of price. I am 100% in this for sound quality.
Pg Tantrum Comes To Mind Too..
When I Was Gonna Add A 2nd 12w7 When I Had 1, I Contact Pg And They Said Amp Would Be Fine.
Being Rated At 1500.1 @ 2ohms Min I'd Assume U'd Get Even A Bit More Than That @ 2ohms And Even So At 1.5... (1 Yr Warranty And Ebay)..
Most 2 ohm amplifiers will probably be stable @ 1.5 ohms ... MTX 1501D comes to mind ...
If you arnt pushing an amp to hard and its 2 ohm stable it should be able to handle a 1.5 ohm load. That dosnt mean it's ok though. An MTX amp could probobly handle a 1.5 ohm load because they make pretty good amps. I would try using a Rockford Fosgate 1500 watt RMS amp (cant remember the model number off the top of my head). You might want to look at Eclipse's DA7122 or even JL's 1000/1.
Trutech Sledgehammer (SH-1). 3500wrms @ 1.5ohms will definitely feed those beasts, very cleanly. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
399
There is still power in the radio. Internal amplifier in the radio. Even when turned off. The radio is connected to external power amplifier...
7
350
I'm sure she will be happy with just about anything. Coming as someone who was a teenager just a few years ago, bass is the big thing especially...
5
256
I bought it from Amazon last year.. i have had plenty of bad products from amazon :(
15
528
cjjackson85
Banned
cjjackson85
Idaho
limitkid7
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
