matching speakers with amp.
benyboy.
uk
hi guys i need help i have sort of hit a brick wall as in im unsure how to match a subwoofer to my amp .
im looking for a focul or ground zero pref this make of subwoofer already built into a box unit i am fairly new to car audio.
so i am not sure what wattage it needs to be and how many ohms as i dont want to overheat my amp or damage it..or if i need to put a capacitor in line ect i have tried to look online and work it out but i am afraid it now has just overwhelmed me with all the diff information given all i want to do is put in a subwoofer.my amp is a ground zero titanium GZTA 4125X-II it is a 650w amp 4 channel TRIMODE i presently have all 4 speakers connected at 4.ohm manual says i can connect 2 speakers bridged at 4 - 8.ohm but i only want to connect 1 subwoofer can anybody tell me what ohms my subwoofer needs to be so not to overpower my amp and wattage min i need plus any capacitors ect i would need to use.
To match a subwoofer to your Ground Zero Titanium GZTA 4125X-II amplifier, it's essential to consider the power handling, impedance, and wiring configuration. Let's break it down step by step.
### 1. **Understanding Your Amplifier**
- **Power Rating**: Your amp is rated at 650 watts total in a 4-channel configuration. When bridged, the power output can change based on the impedance of the connected speakers or subwoofers.
- **Impedance**: The manual states that you can connect a load of 4 to 8 ohms when bridged. To utilize the full potential of your amp while ensuring safety, you should choose a subwoofer that matches these impedance ratings.
### 2. **Selecting the Subwoofer**
- **Impedance**: For a single subwoofer connected in a bridged configuration, you should look for a subwoofer rated at **4 ohms**. This will allow your amp to deliver more power without exceeding its limits.
- **Power Handling**: Look for a subwoofer that can handle between **300 to 600 watts RMS**. This range ensures that you are not overpowering the subwoofer and it can adequately handle the output from your amp.
### 3. **Capacitors and Additional Components**
- You mentioned needing a capacitor. Typically, capacitors are used to help with voltage drops when the bass hits hard, especially in systems with high power. However, with a standard setup like yours, a capacitor is not strictly necessary unless you're experiencing significant voltage drops or dimming lights when the bass hits.
- If you do decide to add one, a capacitor rated around **1 farad** should be sufficient for your setup.
### 4. **Wiring Configuration**
- Make sure to wire the subwoofer correctly according to its specifications. If it's a dual voice coil subwoofer, you can choose how to wire it to achieve the desired impedance (4 ohms in this case).
- Follow the wiring diagram on the subwoofer or refer to your amp's manual for bridging configurations.
### 5. **Installation Tips**
- Ensure that your amp has proper ventilation to avoid overheating.
- Use quality wiring that can handle the power being delivered.
- If possible, adjust the gain and crossover settings on your amp to match the subwoofer for optimal performance.
### Conclusion
In summary, look for a **4-ohm subwoofer** rated between **300-600 watts RMS** from Focal or Ground Zero, and you should be set. Make sure to handle the installation carefully, and consider a capacitor if you notice any voltage issues.
If you have further questions or need more details, please feel free to ask, and let's see if other members can chime in with their advice!
thank you for the reply it is so much easier to understand put like the way you have on the net it reads so differently and after reading many post trying to understand what i need it gets over bearing the reason i asked about the capacitor is the manual does list them like this.
frequency......inducter.....capacitor
80 hz......... 7,7 mH........470 uF
100 Hz....... 6,5 mH .......330 uF
120 Hz..........5,5 mH...... 370 uF
150 Hz.........4 mH .........220 uF
values for a 6 db passive crossover above..
it also goes on to mention ...use 100 volt, non-polar capacitors for a high pass crossover to filter out low frequencies. and air-core or ferrit-ore coils with a minimum of 1mm for the low pass crossover to filter out high frequencies......
do i need any fitting thanks.
benyboy.
benyboy.
uk
benyboy.
