Need help picking a sub
Riley1138
Mi
Ok so I got a 4ch amp 150w per chanel 2 are taken by 2 6x9s and I'm thinking of bridging the other 2 and putting that 300w into a 10in sub, im pretty new to this so what do yall think would be the best sub for this setup car is a 79 camaro if wondering
It sounds like you’re putting together a solid system in your 1979 Camaro! Bridging the two channels of your 4-channel amplifier to power a 10-inch subwoofer is a common approach to increase bass output. Here’s what you should consider when selecting the best sub for your setup:
### Subwoofer Selection:
1. Power Rating:
- Look for a subwoofer with a power handling capacity that matches or is slightly below the 300 watts RMS that your amp will output when bridged. Ideally, the sub should handle around 200-300 watts RMS to ensure you’re getting the most out of your amplifier without risking damage.
2. Impedance:
- Make sure the impedance of the subwoofer matches your amp's output. Most 4-channel amps will output the rated power at 4 ohms when bridged. Thus, you should look for a subwoofer with a 4-ohm voice coil or a dual 2-ohm voice coil configuration wired in series to achieve 4 ohms.
3. Enclosure Type:
- Consider the type of enclosure you’ll be using for your sub. A sealed box typically offers tighter, more accurate bass, while a ported box provides louder bass but can be less controlled. Given the 79 Camaro’s limited space, a sealed box might be a better choice.
4. Size and Depth:
- Ensure that the subwoofer can fit in your chosen enclosure and your car. The space in a classic Camaro can be tight, so check the mounting depth.
### Recommendations:
Here are a few subwoofer options that fit well within your parameters:
- Rockford Fosgate P10D2
- 10” subwoofer with a dual 2-ohm voice coil. It's rated at 300 watts RMS.
- JL Audio 10W0V3-4
- 10” sub rated at 300 watts RMS and available in a single 4-ohm version.
- Kicker 43CWR104
- This is a 10” sub with a dual 4-ohm voice coil that can handle up to 300 watts RMS.
### Installation:
- When bridging your amp, typically you will connect the positive terminal of channel 1 to the positive terminal of the sub, and the negative terminal of channel 2 to the negative terminal of the sub. Make sure to check your amplifier’s manual for the correct bridging procedure.
### Final Thoughts:
Double-check all specifications and dimensions to ensure everything fits. Also, remember to use proper wiring and fusing to prevent any electrical issues.
Please feel free to ask additional questions or for further assistance, and let’s see if any other members have suggestions!
Riley1138
Riley1138
Mi
CarAudio.com - Hal
RobGMN
    Jun 8, 2026
DEH-P7700MP.mp4
lbn.wrks
    Jun 8, 2026
