A sub to play that high would be a bad fit in that kind of system. 10" inch pa mids crossed a bit lower on lower than rms power would be a better option because of the sensitivity...but no matter what you're not gonna really notice that gap at full tilt.Because there isn't enough room for the subs you want to run inside of the cab. But there is room inside of the cab to run something different or to try and fill in 80hz and above. This is just brain storming for SPL types of systems.
As the pressure builds on your ears, the ability to hear full range of frequencies starts to fall off. That's why a lot of bass at high volume will give the "underwater" sound.
2 stereo integrity sql-15's on 3k in a sealed box was able to do that in my old saturn. And that wasn't an spl build
