Need new door speakers . Need options
sounds_explicit
Looking to spend maybe 400 on total of 4 mids. 6.5's
Going to pair up with 3 xv3 15s I have a rockford 600.4 to use for the amp. Needing some good recommendations on mids to run.. needs to keep up with the sub stage. Strongly leaning towards sundown neo pro v3 but they are last on list for price .Also they wstocbe going in stock door locations do i need just mid bass or do I need mid range ?
Also
Also
Considering you are trying to keep up with 4 15s midbass just isn't gonna happen anyway. 100hz hpf minimum and send it on whatever
Sundown neopro are very good pro audio midranges. Add in a pair of nice tweeters on the apillars or dash corners and it should be ok.
242
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
263
521
sounds_explicit
sounds_explicit
cleveland ohio
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
