What amp should i get
Use a volteter set to ac voltage on the speaker outputs without the speaker hooker up and use this formula
Volts(ac)=√(watt×ohm)
20(VAc)=√(400×1)
Set the amp to 20v ac on the amps output. Adjust the gain until it's at 20v ±1v
so for my car it would be 12v+_1v because i have a 12 volt battery?
Yes
That will set the output to 400w any any extra eq will just eat into the headroom which is fine. The sub should take slightly more than RMS power without issue. Then later you can upgrade to a larger sub if wanted and still have power to spare
ok i understand it now thank you so much for your help
would you recommend this over the d4s jp8?
I would recommend this over the DFS JP8 for the money, or spend $10 more than the DFS JP8 and grabb a 1500.1
turb00
turb00
harleysville
