Static noise after upgrading the head unit
  • 2
maxi923
Hi
its been a while since I upgrade my car's head unit to an android Chinese touch screen. Since then, I could not find a solution to the issue.
I am getting static and digital processing sounds through my speakers. If I mute the head unit there is no static or other sounds.
Static and digital sounds do not increase with volume, it remains the same no matter what volume it is at unless the head unit is muted. Also, the static sound exists even when the engine is off.
Sound is going through my Nissan factory amp.
After a lot of research, I found a similar issue explaining the issue that the problem is the sound is amplified from my car's amp and from the head unit again which cause a static noise. And it was suggested to use inline filter or LOC's
I m not an expert at these and unfortunately, I don't have a local shop that understands these stuff!. I googled Loc's and found 2, 4, and 6 loc channels. Not sure which one should I buy if these would fix the issue.
Any thoughts would be appreciated.
Mant thanks
Hello Everybody, So I have been having unwanted static noise (live wire type noise), along with the usual White Noise Hissing + some EMI/ very...
Try and use the factory ground wire in the harness instead of chassis ground to see if it makes a difference
856
I was listening to music one day and after pausing it on my phone (i was using Bluetooth) there was a very present static, It has been working...
maxi923
maxi923
Saudi Arabia
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
