Wiring, Electrical & Installation
Post and discuss your car audio wiring, equipment installation and electrical questions here.
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
I use the small metal screwdrivers made for electronics.
??????????????????????????????????/Is this your sub model#??????????????????????
794
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
Yes I will be sure to do that and thanks for the advice/help.
18
14 ga. for me. Not necessary, but I like the "headroom",
977
Your math might make a lot more sense when playing a Sin wave. Music doesn't draw near as much current. Hence why I was able to keep a 60amp fuse...
17
I don't why this didn't click for me till I saw your post. I realized I've been pretty lucky over the years myself and that I need to rewire my...
15
13K
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
Try one of your local auto recycling yards, or your GM dealer parts guy.
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
Interesting topic. I just ordered 2 Focal KX25s (10inch Subs) and I am looking for SQ over SPL. Is It possible to still get good SQ in a ported...
17
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
942
I hope this help, but in my car, i had this issue because it was picking up a signal from the head light (bulb), so I moved the cross overs to...
Better off just using speaker wire made for that or 9 wire wire if using an amplifier.
I have a couple questions - Is it worth it to use both the MatrixPlus and the Epicenter ? I wanted to try it but I am having problems with where...
That or with a TB, you either have an amp, or those early 2000 years on the full size tahoe, they were wiring them in series. It's most likely...
939
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Only a year late with that reply...
15
5K
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
967
Need more info. What is the year of the auto, what is the stock system, and what equipment are you trying to put in its place would be a good...
Yes. No problem, and no different than using outboard crossovers mounted up in the dash or near the amp.
811
The factory amp is junk, and you should just get rid of and run new wire from your new head unit. Your amp is going to have two wires that...
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
I would pull each speaker and test as well . Check with a DMM and a different HU or? as stated. A 12v battery and an Old HU usually works just fine
960
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
To me.. It looks like the Allen head screws are in the terminals on the speaker inputs on the amplifier. The negative looks like its in there and...
Wire to the 2ohm diagram as shown for the MTX subs on the one amplifier you have. That amp should do very well on those two subs. alpine make some...
981
Looking to upgrade my 05 Acura RL with some modern stuff, like gps, backup cam, Spotify, etc. The car comes stock with the Bose 10 speaker DTS...
Did you ever find the issue. I’m fighting the same battle with the same amplifier. Was performing tremendously and then one day it started cutting...
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
941
Create account or login to post/reply
You must be a member in order to post a message.
Create account
Register below to post messages:
Log in
Already have an account? Log in below:
Messages
391,703
63M
alternator amp amplifier battery electrical help pioneer subs subwoofer wiring
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
Top recent contributers
