Post all general car audio discussion topics here. Including sound quality “SQ”, old school and advanced car audio.
can yo find a solution? i have the same issue for the ilx259.
Agreed and Brand X doesn't exactly have the greatest rep to begin with in the car audio community for a decent product.
666
Buddy of mine somehow managed to get small MDF boxes set into the rear doors on his previous truck, think it was an F-150. I can't remember...
718
Man.. ^Thats Great!. This will hopefully help others in the future as well!!
991
Thank you Doxquzme! I appreciate the response and advice.
573
When I stripped my factory system and started from scratch. I didn't need any adapters. I wired the new head unit wiring harness to the vehicle...
676
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
751
Based on everything else you've said so far, I'm wondering exactly how you have the LoC connected "through your subwoofers". Is it possible that...
23
I’m very far from a car audio expert; one only has to see my recent posts around here to know that. I am, however, pretty knowledgeable on cars...
22
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
814
I hold firm on the deposit in all situations 😎
839
@HardofWhoring trigger! Gain isn't a volume knob!
599
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
746
Ok thank you, I'll check where the remote wire is connected and get back to you.
694
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
740
Oh man, that's like s3x with your mother in an elevator, wrong on every level!
27
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
779
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
908
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
938
Anyone have a service manual or belt diagram for the cassette player in a 1987 Delco 16051911? Thanks, Alan
https://www.cdtaudio.com/cdtnew22/ms.php Real good pricing.
22
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
You cannot unless you wire the two speakers in series. If you wire them in parallel, that brings the load down to 2 from the speaker and the...
e heard decent things, I've not used it, but for noobs, good place to start with that new DSP setup...
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
733
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
873
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
871
Nice thing about the Morels is they don't require a lot EQ. Since the midbass will likely be far from the mid & tweeter, you could benefit from...
892
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
920
I know there is a December sale at mclaudio.ca
48
4K
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
783
Create account or login to post/reply
You must be a member in order to post a message.
Create account
Register below to post messages:
Log in
Already have an account? Log in below:
Messages
1,031,563
96.8M
alpine amp amplifier car audio head unit help pioneer speakers subs subwoofer
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
Top recent contributers
