Make sure you follow the exact wiring diagram shown for the two subwoofers for the final Ohm Load at 2 ohmsHow would I determine/fix that?
Option 2 (series/parallel) = 2 ohm load Voice coils wired in series, speakers wired in parallel Recommended Amplifier: Stable at 2 or 1 ohm mono |
Yes I did. Here is how the subs came wired from the manufacturer. I connected the negative wires of both subs and put them in one of the neg terminals and did the same with the positive in one of the positive terminals.
You need to wire the subs EXACTLY as the Diagram shown for your 2 DVC2 ohm subs for the Final Ohm load and you only need to use one set of terminals on the amplifier. Did you wire them exactly as shown?If not.. follow the diagram for the two ohm as shown.
You can check with a DMM on Ohm Settings to check the final two wires(One Poss and One Neg ) that go to the amplifier to make certain that the final Ohm load is within the 2 ohm Limitations. will not be exactly 2 ohms, more like 1.8 up to 2.3. If it jumps around alot then You may have a bad coil on one of the subs. You will need to check each coil individually without any wires attached, and be around the same limitations. quite possible you may have a bad coil on one of the subs as you stated a "Rattle " from one of the subs?Yes I did. Here is how the subs came wired from the manufacturer. I connected the negative wires of both subs and put them in one of the neg terminals and did the same with the positive in one of the positive terminals.
Checking the last two wires from the subs that go into the amp and it’s showing around 1.5 ohms. Would that mean the amp is the problem then? Gonna check both the coils on the sub I think is bad and will get back to you. Also I contacted the seller and they offered to send me a new amp once I return mine and possibly another sub if I test it and it seems defective.You can check with a DMM on Ohm Settings to check the final two wires(One Poss and One Neg ) that go to the amplifier to make certain that the final Ohm load is within the 2 ohm Limitations. will not be exactly 2 ohms, more like 1.8 up to 2.3. If it jumps around alot then You may have a bad coil on one of the subs. You will need to check each coil individually without any wires attached, and be around the same limitations. quite possible you may have a bad coil on one of the subs as you stated a "Rattle " from one of the subs?
Need to remove the Jumper wires and test each coil Pos Neg and Poss neg. Subs have Two 2ohm voice coils. See if both are close to 2 ohms each. I know its a PITA but need check Ea coil. With the Jumper your are within the 1 ohm limitations, But need check ea coil for 2 ohms. very well could be the enclosure rattling if its leaking or flexing without some bracingTested the sub that was rattling and showed around 1.5 ohms. So might just be the box rattling I’m not too sure, it does seem to make some noises that the other sun doesn’t. Almost crackling.
You need to remove the Neg on the DMM where it is and put it in the Neg terminal on the other Coil that has nothing in it to read a final Ohm Load on the Speaker with the DMM and Jumper installed. It should read close to 4 Ohms If it is a DVC2Tested the sub that was rattling and showed around 1.5 ohms. So might just be the box rattling I’m not too sure, it does seem to make some noises that the other sun doesn’t. Almost crackling.
Option 2 (series) = 4 ohm load Voice coils wired in series Recommended Amplifier: Stable at 4, 2, or 1 ohm mono |
4GA Power cable and 16GA speaker wire. I ground it on one of my rear seat bolts. Ground wire is also 4GA.
So I checked the wiring of the subs and they already came bridged and the first time I wired them to the amp I just connected speaker wire from one neg terminal on the box to a neg terminal on the amp and did not connect it directly to the other neg terminal on the box and same with positive. This amp is one channel but has 2 sets of speaker terminals. So idk if it made a difference that I changed it but tonight I followed the wiring diagram above and disconnected one of the pos and one of the neg wires from the amp and connected them to the terminals for the other sub. Again not sure if this was needed since I have 2 sets of speaker terminals.
Tested it out and seemed to operate the same as before. Has pretty good bass but only when the gain is all the way up, EQ for bass is maxed, and volume level is ~65%+. That can’t be how it’s supposed to be, right?
Also one of the subs makes a pretty distinct “rattle” sound especially at higher hz.
I’m not sure what else to do.
