Is it necesarry to let speakers/subs warm up before really pushing them?
rbtrucking
I was just curious because winter is rolling around. Is it necessary to let speakers warm up a little before you push them? Just wondering if the fact that they are really cold and moving extremely fast could something get ripped after sitting all night in the freezing weather?
Well I myself might be leaning toward its probably not the best idea to push em too hard when they are cold though I have and nothing has happened. Another thing to take into consideration is what may seem cold to us might not be cold at all to a speaker.
I doubt there's any cold temperature on earth that would make foam/rubber or cotton/nomex brittle. As far as a cold motor/coil that will probably gain you a little more thermal power handling.
If you're pushing something close to its limits anyway and it breaks on a cold day it's not the fault of the cold IMO.
I live in South Dakota, and if I leave my car out overnight or let it sit in cold, winter weather for ~5 hours, my subwoofer will hardly play at all until the heats been going for around 10 minutes.
Its an equipment dependent idea. I know Skar subs that utilize the surround they do will actually freeze and crack the surround upon being cold and played at 1/2 excursion.
I normally let me truck warm up to a decent level before taking off in the mornings anyway and in the mean time everything is playing. So by the time I get in and drive it's all fairly warm.
could you explain this more
Because I have a skar, I just make sure to turn the remote knob all the way down so it doesn't play
Maybe Jacob will chime in here... His guys he sells to in Russia IIRC where having troubles with the surrounds on there subs due to the extreme cold which is why Jacob decided to start using foam more
Nothing else needed to describe how the surrounds fail. It's a given with those junky ones. Nothing else you can do but get a recone or if you know what you're doing re-foam it with a different surround.
the only thing is that the suspension, and the surround get stiff, but if your talking about woofers i actually run more power to them in the winter because then i don't have to worry about thermal failure (as much).
it depends on the materials they are made out of.
In the end if the surround "shrinks" or gets "hard" it can crack from stress. This is common with various styles of rubberized surrounds. Foam is not as problematic with those issues though.
Everyone has different opinions on that, but from what I have seen over my many years is just that.
I have never seen spider failure do to cold weather conditions though.
i had built a spl sub, was very cold that day at comp like under 40F. i didnt get notice of im on deck so was told get up there no chance to warm the sub up a little and i destroyed the coil. there was .009 gap so not ur normal sub,lol. i had burped it many times the day before and before the sub, there was no glue failures just coil rock from cold surronds/spiders....
With your MS-275 and the AC LC 4.300 you will have 8 channels of amplification for the front and rear comps. You will go from the head unit to...
76
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
265
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
402
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
220
rbtrucking
rbtrucking
west hartford ct
    May 31, 2024
    May 24, 2024
