Results 1 to 6 of 6
Reload Thread: NO power to head unit
    Steve Lama's Avatar
    Steve Lama is offline Junior Member
    Jul 2002
    PA
    Icon33 NO power to head unit
    I recently purchased a JVC-S580 head unit. After connecting the 12v and ground wires i cannot get any power to it. I also had this problem with two other aiwa head units and took them back thinking they were broken. I am trying to put it in an 89 pontiac firebird. My after market tape player still works when i reconnect that so i am confused as to where the problem is. The negative battery terminal was disconnected so im sure i havent shorted it. Any suggestions?
    Apr 2002
    sherwood park, AB
    40
    make sure ur remote wire is correct. u can have the power and ground right but u need a remote to turn it on.To check it run a wire from the remote on the headunit and fuse it into the fusu box under the radio fuse! this is a switched remote so that when the ingnition is turned on teh power is sent to turn the radio on check that or try runing a power wire rigth from the battery.
    chris229's Avatar
    chris229 is offline CarAudio.com Elite
    Apr 2002
    Wilm, DE
    39
    1,107
    do this-- twist the radio's turn-on and the radio's power wire together. connect them and the ground directly to the battery. It should power up. if it does get a test light or a volt meter and test--- power,turn on ,ground for the radio.
    Steve Lama's Avatar
    Jul 2002
    PA
    How do i connect straight to the battery or the fuse box?
    Apr 2002
    sherwood park, AB
    40
    well to just check it i attached a wire loosely to the radio fuse in the fuse box and then the power wire to the power wire in the wiring harness this is to just check the remote. if that still doesnt work double check all the connections.
    Apr 2002
    sherwood park, AB
    40
    to the battery all you gotta do ias run a wire fromthe pwoer wire to the postive terminal on the bat . if this slal still doesnt work then assk someone who knows what thre doin to take a look. peace
