ok... i'm installing on this newer civic.... it has some weird terminal thing over the positive battery terminal on the battery... it has a few fuses on it, and other than that it just makes it a pain in the *** to hook a power wire to it. Any suggestions?
the fuses are on this little box thingy that is attached via the battery terminal by the standard ring nut/bolt setup... could i use a two-way power distribution terminal top and just run that box thing into one port, and my amp wiring into the other?
Originally posted by darkimportgrey the fuses are on this little box thingy that is attached via the battery terminal by the standard ring nut/bolt setup... could i use a two-way power distribution terminal top and just run that box thing into one port, and my amp wiring into the other?
you mean after market battery terminals?? yea If the fuse box has a wire that goes to the clamp
Bookmarks
