Results 1 to 2 of 2
Reload Thread: Fuse Help
    Hades2004's Avatar
    Hades2004 is offline Underworld Master
    Dec 2004
    Canada
    27
    278
    Fuse Help
    Okay, my amps both have 2 30 amps fuses on them. Then I have a fused disturtion block that goes to each amp. Each power cable from my block to my amps is about 2 feet. I have 2 60 amp fuses in my block. Now I was wondering, for my inline fuse, I have a 80 amp fuse, should I get a Midi fuse? Would it be fine with a 4 gauge power cable. Also the Midi fuse I was looking at getting for my inline fuse was 125 amp fuse. So would it be fine to go to this Midi 125 amp fuse or just keep my 80 amp AGU fuse?
    Car project to start in July or August of this year.
    sumone's Avatar
    sumone is offline CarAudio.com Veteran
    Dec 2003
    Midwest
    3,416
    Re: Fuse Help
    you're probably fine with the 80. if you play your system at max volume w/o the fuse blowing, skip the 125.
    best sig of all time
  1. voltage after fuse reading low
    By josh1980 in forum Wiring, Electrical and Installation Help
    Last Post: 03-21-2005, 04:12 PM
  2. Fuse Problem
    By jb2xx in forum Wiring, Electrical and Installation Help
    Last Post: 12-20-2004, 04:18 PM
  3. fuse rating size for ANL holder
    By c0la in forum Wiring, Electrical and Installation Help
    Last Post: 12-09-2004, 01:56 PM
  4. Quick Fuse Question
    By Jamesr316 in forum Wiring, Electrical and Installation Help
    Last Post: 10-29-2004, 05:35 PM
  5. question about amp with external fuse
    By treefitty in forum Wiring, Electrical and Installation Help
    Last Post: 01-02-2003, 07:40 AM
