Results 1 to 7 of 7
Reload Thread: running the power wire UNDER the car
    Insomniac119's Avatar
    Insomniac119 is offline i can't sleep
    Nov 2004
    Wichita, KS
    40
    673
    I was just wondering if anybody here has run their power wire under the body of their car, for huge wire like 1awg or bigger. I guess you'd have to drill a hole somewhere in the trunk, make it water proff, somehow protect the wire from errotion, etc. So, does anybody have any tips and tricks?
    ax600's Avatar
    ax600 is offline CarAudio.com Elite
    Mar 2005
    grand forks N.D.
    696
    1 Post(s)
    Re: running the power wire UNDER the car
    I am currently running my 4ga power cable under the floor in my ford explorer. This has worked very good for me in the past on other vehicals as well,(1991 explorer,1996fi50)
    The best advise I could give you is to cover the entire wire with split loom tubing,and either use frame clips,adel clamps to fasten the power cable to the frame. I am also using a firewall gromit that screws togather. You install one side of the gromit on the top side of the floor and the other on the bottom. this gromit will self seal and when you tighten it down it also snugs up arround you'r power cable. wow that was a run on but I hope it will help you out.
    THUNDERBIRD's Avatar
    THUNDERBIRD is offline CarAudio.com Veteran
    Feb 2005
    LANSING, MI
    2,316
    i have seen a car were someone ran the wire straight over the car and his rcas and remote from the hu to the trunk could have used it as a clothes line also
    94' thunderbird *parked*<
    4.6 V8 with a shift kit
    clarion dxz 645mp clarion sirius tuner
    ED 6000v.2- front jbl 5.25 comps- rear
    dynamated and edeaded trunk lid, rear deck, front doors
    Big 3 in green of course
    viper 791xv w/ battery backup
    3 jl 10w0
    2000 ford ranger supercab 3.0v6 4x4
    stock hu
    alpine mrp-m350
    2 9kv.3's
    clifford matrix rsx 50.5x
    spring time getting clarion MAX675VDII and front components possibly jbl's again
    Chevyaudio's Avatar
    Chevyaudio is offline :poof:
    Mar 2005
    Back in the Dirty BR, Louisiana
    30
    13,157
    yeah i run my 1 guage under my 04 silverado, no problems, just be sure and use gromets when you run the wire thru a metal hole
    cjjackson85's Avatar
    cjjackson85 is offline Banned
    Mar 2004
    Idaho
    32
    9,061
    I ran my 1/0 power wire underneath my Suburban in 1'' flex conduit. You can buy this stuff by the foot in the Home Depot/Lowes electrical department. I then zip-tied the entire lenght inside the frame underneath the car. You can use a rubber grommet to bring the wire back into the cabin. Hardest part was finding a drill bit large enough for my grommet.
    deaf tones's Avatar
    deaf tones is offline Senior VIP Member
    Mar 2005
    bay area
    469
    dremmel
    yes, i've ran it underneath the car but was dumb enough to not look twice at where I was drilling and ended up with a hole right next to the exhaust. Hey...at least I didn't go on the other side next to the gas lines hahahaha
    (ended up using the hole for a screw in battery post to the bare metal as an extra ground. underside went to the frame after...top side went to the mid amps)
    Nov 2004
    Wichita, KS
    40
    673
    where did you find the rubber grommets at?
  1. Connecting two pieces of power wire / Strand Count
    By Chris02NeonSXT in forum Wiring, Electrical and Installation Help
    Last Post: 01-17-2005, 08:14 PM
  2. Question about power wire.
    By alti98 in forum Wiring, Electrical and Installation Help
    Last Post: 12-16-2004, 01:25 AM
  3. new power wire
    By Wowimzz in forum Wiring, Electrical and Installation Help
    Last Post: 12-09-2004, 10:58 PM
  4. power wire to fuse holder
    By Looney_Tune in forum Wiring, Electrical and Installation Help
    Last Post: 11-10-2004, 02:15 PM
  5. 2 Amps, 1 Power wire
    By RFFreak4Life in forum Amplifiers
    Last Post: 05-29-2002, 09:55 AM
