Results 1 to 7 of 7
Reload Thread: Battery Clamps
    kronik's Avatar
    kronik is offline Audio Nooblet
    Jan 2005
    Chantilly, VA
    304
    Battery Clamps
    Not sure how to describe this.. all the cars I've ever worked on, however, have been similar.
    The Optima Yellow Top obviously is not a completely flat battery on the top so the clamp fits kinda on one side, and not exactly on the other. That's fine, but the little pole (?) that you screw through part of the clamp and hook in the hole under the battery to tighten it.. is too long for the battery itself. I put some eDead v1se to basically push the battery up a little more but it's still too far to be tightened. Does anyone know where to get a shorter pole? All it is, is a rod that has a little hook on one end and a place to screw a nut on the other, but the threads only go so far down the rod, and I need about an inch more to tighten it.
    Thanks.
    1999 Camry XLE V6
    STUFF FOR SALE -
    Alternator: Excessive Amperage 200A
    Tweeter/Crossovers: CDT Upstage System UP-219
    Referrals:
    johnecon2001
    saosin
    Toxic Tuan
    lslugz
    XtrmAudioCncpts's Avatar
    XtrmAudioCncpts is offline CarAudio.com Veteran
    Mar 2005
    Fairfax, Va
    31
    4,294
    Re: Battery Clamps
    if you can, cut it
    Quote Originally Posted by Devillain00
    XAC = pimpin since been pimpin
    kronik's Avatar
    Jan 2005
    Chantilly, VA
    304
    Re: Battery Clamps
    Quote Originally Posted by XtrmAudioCncpts
    if you can, cut it
    I'd have to be able to hook the bottom.
    Can't cut the top, because I'd lose threads.
    1999 Camry XLE V6
    STUFF FOR SALE -
    Referrals:
    johnecon2001
    saosin
    Toxic Tuan
    lslugz
    Mar 2005
    Fairfax, Va
    31
    4,294
    Re: Battery Clamps
    i dont know if i can really understand the problem with out seeing it can you take a pic of it?
    duece212's Avatar
    duece212 is offline Buddy Christ!
    Jan 2005
    Colorado
    10,695
    3 Post(s)
    Re: Battery Clamps
    cut it and rethread it if you have a tap/die set. If not, and its kinda cheesy but can you shim under the mount where the rod goes with some washers?
    johnecon2001's Avatar
    johnecon2001 is offline SSA/ROE Super-Møderator
    Aug 2004
    Phoenix, AZ
    35
    5,137
    Re: Battery Clamps
    Something like this??
    Don't PM me, I'm not here. Find me on SSA or ROE
    No, I won't re-upload the Big3 pictures. Don't ask.
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Re: Battery Clamps
    I assume you're talking about the hold down clamps that secure the battery to the tray? There are universal jobbers you can get at any auto parts store... or if you're feeling cheap stick a hunk of plywood under the battery.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. Hood damage from Battery
    By Decipha in forum General Discussion
    Last Post: 06-26-2005, 08:12 PM
  2. replacing main battery
    By IshbOO in forum Wiring, Electrical and Installation Help
    Last Post: 02-06-2005, 01:17 AM
  3. Starter killing battery.. help please
    By mickyd32 in forum Car Video, Security and Electronics
    Last Post: 10-07-2004, 11:51 AM
  4. Help solve the Mystery of the Dying Battery!
    By Diabolic in forum Wiring, Electrical and Installation Help
    Last Post: 01-16-2003, 04:24 AM
