Results 1 to 5 of 5
Reload Thread: grounding kit vs "big-3"
    M@nJo's Avatar
    M@nJo is offline CarAudio.com Elite
    Mar 2005
    bay area
    1,461
    Icon30 grounding kit vs "big-3"
    i went to a local audio shop and talked to them about the "big-3". they were pretty much thinking "wtf is the big-3?". then i told them it was neg to chassis, positive alternator post to positive battery post, and engine to chassis. then they knew what i was talking about.. a grounding kit
    i thought a grounding kit is different than the big-3 upgrade?
    as for as i know, the big-3 upgrade involves:
    1) negative battery post to chassis
    2) positive alternator post to positive battery post (w/fuse)
    3) engine to chassis (or alternator mounting post to chassis, since the alt is mounted onto the engine block)
    and a grounding kit involves:
    1) negative battery terminal to tranny ground point?
    2) from tranny to firewall
    3) from firewall to chassis/factory ground point
    4) from negative battery terminal to chassis/factory ground point (preferably radiator support ground point)
    5) chassis to engine (or valve cover)
    can someone verify that a grounding kit is completely different to the "big-3" upgrade? or are they somehow similar at some point?
    and lastly, which of either 2 benefits what?
    Ignatowski's Avatar
    Ignatowski is offline CarAudio.com Veteran
    Mar 2005
    Dirty South
    6,854
    104 Post(s)
    Re: grounding kit vs "big-3"
    retailers scare me sometimes
    grounding to valve cover? wtf most valve covers are aluminum
    tranny to firewall? well,thats allmost like engine to chasis just a confusing way to explain since the tranny is connected to the engine
    its all pretty simple -
    BAT NEG TO FRAME/CHASSIS - I prefer actual frame rather than sheet metal
    neg frame/chassis to engine -
    pos alt to pos bat (fuse optional) some guys run fused some dont - its not a bad idea but I dont
    Decipha's Avatar
    Decipha is offline www.EFI Dyno Tuning.com
    Mar 2005
    New Orleans, LA
    29
    3,265
    2 Post(s)
    f**k the grounding kit I would rather the Big 3 since it would be cheaper and less time consuming than running all that unnecessary wire
    time is money... money brings happiness
    Quote Originally Posted by excelerater
    ^^thats the reason why only i work on my car because i know exactly whats going on
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,235
    1 Post(s)
    308 Post(s)
    big 3 and grounding kit are diff things.....
    Nightskye's Avatar
    Nightskye is offline Member
    Feb 2005
    East Bumfvck
    140
    Useless. The only grounding I have are the Big 3 and I'm planning a common ground wire for my 2 amps running from the negative battery terminal to a ground distribution block in the trunk and split off to my 2 amps. From there, each amp grounded to the chassis in the trunk.
    You don't even really need the common ground, I just did it for extra protection. Big 3 grounding and just grounding your amps to the chassis in the trunk would be fine.
    '06 Civic Sedan
    Clarion DXZ855MP
    PPI PC4800.2
    ID CTX65CS
    IDQ10v3
    Second Skin deadened
  1. Step 1 of the "Big 3"
    By [email protected] in forum Wiring, Electrical and Installation Help
    Last Post: 03-26-2005, 09:40 PM
  2. "Big 3"
    By Randy Savage in forum General Discussion
    Last Post: 02-02-2005, 04:00 PM
  3. "Big 3" wiring for a boat...
    By SoundsGood in forum Wiring, Electrical and Installation Help
    Last Post: 01-22-2005, 06:18 PM
  4. Question about Scosche 4ga. wiring kit
    By S0CalS0L in forum Wiring, Electrical and Installation Help
    Last Post: 11-19-2004, 09:40 PM
  5. what is the "Big 3"?
    By Professor Fate in forum General Discussion
    Last Post: 10-31-2004, 11:02 PM
