Results 1 to 3 of 3
Reload Thread: 2 1200 watt amps, bigger battery and alt.???
    BloodThirst's Avatar
    BloodThirst is offline Junior Member
    Mar 2005
    Ellsinore, MO
    30
    Icon32 2 1200 watt amps, bigger battery and alt.???
    ok im going to run 2 Kicker KX1200.1 amps with 1 Kicker Solo-Baric 04S15L7 15" sub and 2 Kicker Solo-Baric L5 05S12L54 12" Subs in a 1998 Jeep Cherokee with stock power supply.
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    36
    13,103
    21 Post(s)
    Re: 2 1200 watt amps, bigger battery and alt.???
    you shouldnt run 2 different sizes.
    you should upgrade the battery
    you should post model numbers so we can help you better
    welcome to the board btw
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    [email protected]
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
    TimberJon's Avatar
    TimberJon is offline Member
    Feb 2004
    LA, CA
    136
    Quote Originally Posted by BloodThirst
    I need some help i need to know what kind of power im gonna need to push to run 2 1200 watt kicker amps 1 15 kicker sub and 2 12 kicker subs. im hoping some finds out.
    Doesnt really matter what kind of power. Go overkill, So later on your power equipment will be able to power a better system.
    Better than a 140 amp alternator, No more than a 250.
    www.excessiveamperage.com
    www.h-o-alternators.com
    A Deep Cycle battery, suggesting an Optima Yellow Top, call their customer service and tell them your vehicle type, and they will suggest two model numbers. One for the Red Top, and one for the Yellow Top. Go and buy the Yellow top model. www.1st-optima-batteries.com
    THEN, have your new alternator installed by a certified professional. preferably someone certified to work on your brand of car..
    Make sure the zero gage power cables running to your trunk are all fused with the correct amperage. Try to get your hands on a capacitor of 10+ Farads. Hybrid capacitors are OK. www.stingerelectronics.com
    For battery terminals and power/speaker wire. visit the following sites.
    www.Stingerelectronics.com
    www.knukonceptz.com
    www.phoenixgold.com
    www.cardomain.com
    www.infinitecaraudio.com
    To LEARN about the EXACT power figures you will need and that you will consume, read everything relavent to your question on this website. www.bcae1.com
  1. I might be able to get away with my stock battery and alt
    By Hades2004 in forum Wiring, Electrical and Installation Help
    Last Post: 03-13-2005, 03:20 AM
  2. alt over charging battery??
    By paintball9908 in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2005, 12:26 PM
  3. Battery / Alt question
    By Jeff06 in forum General Discussion
    Last Post: 11-17-2004, 08:58 PM
  4. Alt or Battery?
    By raymondau in forum Amplifiers
    Last Post: 02-04-2003, 12:15 PM
