Results 1 to 11 of 11
Reload Thread: Want to have more power.....
    nikosbuddy's Avatar
    nikosbuddy is offline I pooped a hammer
    Oct 2004
    In louisville
    32
    4,868
    2 Post(s)
    Ok i have a stock system...everything *****....
    and if i hook up my amp...it will run yes maybe at 12 volts but my amp can handle up to 18 volts i would like to have like a solid voltage going to the amp, like 14.4 or somethign liek that, would replacing the battery do that or what? because id like to have a decent amount of power coming from my amp for my subs
    im thinking about getting Ng's red top but i dont know yet and im wondering what i should do....
    Mike
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Re: Want to have more power.....
    A high output alternator and an upgraded electrical path is going to be what keeps your voltage constant with the engine on...
    300m_on_xxx's Avatar
    300m_on_xxx is offline BMW 325IS
    Nov 2004
    Fresno, CA
    1,103
    Quote Originally Posted by Jack Frost
    f*** u beat me to it
    i think i have to sign here but who knows
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    about time, after all those threads yesterday
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    Plus batteries are only 12v, your alternator theoretically puts out 14.4v. You should be getting over 12 with your car running, but yeah, then what jack said. Do big 3, new alt etc...
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
    nikosbuddy's Avatar
    Oct 2004
    In louisville
    32
    4,868
    2 Post(s)
    hmmmm...so a stock theordeically does 14.4 right? what if i got like a optima red top i **** with battery and electrical stuff....
    thanks guys
    Mike
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    A Red Top isn't going to help your reserve potential any more; it's a starting battery designed to give lots of amperage when you crank the engine. After that, it functions as a regular lead acid would.
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    37
    6,962
    5 Post(s)
    um...i heard the big 3 increases your chances of blowing up your battery..is this true?
    i know it helps with the flow of current and voltage...just want to know the negative side of the big 3
    80
  9. #9
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    No. The most common failure mode for batteries that results in an explosion is a thermal runaway condition, which requires the current to be disproportinate to the charging voltage.
    That usually results in a nice fireworks show.
  10. #10
    80INCHES's Avatar
    Jan 2005
    WESTCHESTER, NY
    37
    6,962
    5 Post(s)
    ok thanx jack.......i'm going to do the big three on monday or tuesday
    80
    big 3 and a redtop batt....o yeah i'm lovin it.....it should hold my memphis mojo
  11. #11
    skeptikal's Avatar
    skeptikal is offline Hold the wheel and drive skeptikal is a Supporting Member of the forum!
    Jul 2004
    Indiana, US
    4,066
    22 Post(s)
    Do the big-3 upgrade, and if you are still worried about blowing up your battery put like a 200+ amp anl fuse in line with the battery and alternator, so just in case your alt does decide to "shock" your battery, the fuse will blow before the current gets to it and you'll be back down to ~12v.... way better than replacing a failed battery
    2005 Dodge Ram Quad Cab
    Pioneer DEH-80prs
    Image Dynamics X-65
    Image Dynamics XS-28
    PPI 900.4
    Wolfram 1500.1
    Sundown Audio SA-12 D4 (x2)
    Noico deadener
    NVX wiring
  1. hooked up correctly, power, but no sound. :(
    By rubix777 in forum Wiring, Electrical and Installation Help
    Last Post: 12-02-2004, 03:19 PM
  2. Are these power ratings Strange?
    By bushtree in forum Amplifiers
    Last Post: 12-01-2004, 08:07 PM
  3. Theoretical Gains From Power Increase
    By IgnoreMe in forum General Discussion
    Last Post: 11-05-2004, 03:03 AM
  4. MA Audio,audiopipe, or Power Acoustik?
    By jaboran in forum Amplifiers
    Last Post: 10-25-2004, 01:08 PM
