Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Reload Thread: My subs got stolen and now i have a ground loop?
  1. #16
    Mar 2003
    Northeast
    2,408
    8 Post(s)
    Re: My subs got stolen and now i have a ground loop?
    just do the amps and any eq or crossover you have, don't worry about the cd player ground...although it's something to try if you keep getting noise...i've heard of people wrapping their hu in foil there's a lot of different things you can do... as far as power wiring being run with rca's try and minimize it as much as you can if you have to run wires near or together each other make it so they don't run paralell to each other...
    Refs: Diyma.com, Caco.com
  2. #17
    cobra133's Avatar
    cobra133 is offline Member
    Mar 2005
    Atlanta, GA
    33
    71
    The two amps are grounded to the same place. The head unit is using the stock ground. The Remote turn on switch is being run on the same side as the rca cables. Should I try to move it? (it worked like this before).
    thanks
  3. #18
    LBX2G's Avatar
    LBX2G is offline R.I.P Camofluage
    Jun 2002
    Warner Robins
    33
    2,713
    see that is the problem. Reground the headunit to a better ground. and try to make it as short *** possible.
    FREE Terrelll"peanut" Grayer!!!!!!!!!!!!!!!!!!!!!!!!!!
  4. #19
    Mar 2003
    Northeast
    2,408
    8 Post(s)
    don't worry about the hu ground for now...just do the amps
  5. #20
    formlua5150's Avatar
    formlua5150 is offline Conductor, Douche express
    Sep 2004
    LV, NV
    196
    Just use a voltmeter and see ifyou have a good groud. Make sure u get 12 volts from the distro block to the ground (when car is off)
  6. #21
    cobra133's Avatar
    Mar 2005
    Atlanta, GA
    33
    71
    It was the head unit. It got damaged. I've replaced it and everything works fine.
  7. #22
    Black_Jesus's Avatar
    Black_Jesus is offline The Unexpected
    Aug 2004
    lamest place humanly possible
    1,743
    Quote Originally Posted by cobra133
    hoo yea who was right... THIS GUY!
