Results 1 to 4 of 4
Reload Thread: quick relay question
    .::DuD3::.'s Avatar
    .::DuD3::. is offline EE in training
    Oct 2004
    Chesafreak, Va
    30
    4,530
    according the www.the12volt.com it says i must connect terminal 85 to ground, so do i ground the relay or is that for the accesories i'm using?
    crhye250r's Avatar
    crhye250r is offline Installer
    Oct 2002
    Clay, KY
    33
    985
    Re: quick relay question
    Terminals on a SPDT Relay
    87 - Normally open, when closed, is contacted to 30.
    Pin 87a - Normally closed contacted with 87. Opens when relay is energized.
    Pin 85 - energizes relay. (closes 87 to 30) Needs to have ground or 12v
    Pin 86 - energizes relay (closes 87 to 30) Ground or 12v
    Pin 30 - Output to device. When relay is energized, it outputs whatever is input to 87. If 87 has 12v, 12v will come from 30. or vise versa
    If you have any more questions, holler. Hope I have helped. Oh, and 85 or 86 can go to ground. If 85 is ground, 86 needs to have 12v to energize the relay or vise versa.
    MECP Certified Installer
    .::DuD3::.'s Avatar
    Oct 2004
    Chesafreak, Va
    30
    4,530
    yeah that helped a lot, but just to make sure, if i have 87 from 12v source, and 30 to output source, 85 to ground, i'd put my remote in 86 right?
    crhye250r's Avatar
    Oct 2002
    Clay, KY
    33
    985
    Yessir. That would work exactly as planned. I would just like to note that you can switch 85 and 86, or 87 and 30 and it would still work fine. Not that you need to, just trying to help ya in the future.
  1. Quick question on alarms and door locks!
    By GPoodle in forum Wiring, Electrical and Installation Help
    Last Post: 01-12-2005, 08:19 PM
  2. quick question abot sony wire harness for cdxm800
    By DcMaN in forum Wiring, Electrical and Installation Help
    Last Post: 10-11-2004, 09:06 PM
  3. Amps quick question.
    By mssansserif in forum Wiring, Electrical and Installation Help
    Last Post: 01-07-2003, 02:05 PM
  4. Quick question on tue power of my amp...
    By Lord_Vegeta in forum Amplifiers
    Last Post: 01-03-2003, 02:34 PM
  5. Quick question on stereo equip.....???
    By Lord_Vegeta in forum General Discussion
    Last Post: 01-03-2003, 02:32 PM
