Results 1 to 10 of 10
Reload Thread: Help wiring 4 channel amp
    Mar 2004
    Missouri
    66
    Well I decided to amp my 2 planet audio 6.5" component sets. I got a alpine v12 4 channel amp. I wired the amplifier up and ran all of the speaker wires back to the speakers after running the RCA's. I have the front two speakers on channels 1 and 2 and the rear speakers on channels 3 and 4. I ran into a problem on where to hook all of the RCA's up since the back of my head unit has 3 sets outputs(its a pioneer 960mp). One of the sets was for the subs and the other two were mids/highs. On the amp you can put 3 sets of RCA's on it(1&2,3&4, 1+3). I had it all hooked up the way i figured it should go and it sounded great, except for a loud whining noise that got louder as the engine revved. I figured it was a bad ground in the amp so I regrounded it to a place I know is good. Well when I went to turn the amp on it wont kick on, so I finepointed that to the remote wire(I guess it got cut somewhere along the line) so i just bridged a wire from the Positive on the amp to the remote to get it to kick on, but now it sounds crappy. Anybody have any help on how to hook the RCA's up from the head unit to the amp? I have done a search and didn't find what I was looking for. The only thing I found to explain the whining noise is a bad ground in the headunit.Any help would be greatly appreciated.
    P.S-Just wanted to add that some feedback or weird noise is also coming through the sub.
    ashaman's Avatar
    ashaman is offline Member
    Oct 2004
    TX
    143
    Re: Help wiring 4 channel amp
    You should just use the 2 sets of RCA's on your amp. 1,2,3 and 4 channel. Putting two component sets in a car is not really a good idea. It can really mess up your imaging. Try just using one set and see how it sounds up front. As for the whine, check your ground for your amp as well.
    NightRider05's Avatar
    NightRider05 is offline Member
    Mar 2004
    Missouri
    66
    Well I was just using the two sets of RCA's and not using the other one that says 1+3. It actually sounded really good when I first had it hooked up, except for that whining noise. Im not really sure what imaging is so I cant agree or disagree with you on that. I did check my amp ground and I went ahead and grounded it to the same place my other amps are grounded to. The only ground I havent checked is my HU ground. Thanks for the help.
    Hybrid90accord's Avatar
    Hybrid90accord is offline Senior VIP Member
    Jan 2005
    Atlanta
    492
    I hope you did mess up your ground trace on your headunit like i did if so you will have to send it off to get serviced or get a new headunit.
    Mar 2004
    Missouri
    66
    Why would you hope that? Oh and thanks for the help...not
    datguyclark's Avatar
    datguyclark is offline Senior VIP Member
    Jan 2005
    florida
    326
    i think he meant "he hopes you didnt", he is just a retard or something
    johnecon2001's Avatar
    johnecon2001 is offline SSA/ROE Super-Møderator
    Aug 2004
    Phoenix, AZ
    35
    5,137
    For the whining noise that didnt go away... reground the head unit to a piece of the frame under your dash. The remot wire should really be coming from the HU not the 12v constant line. Do it right, the first time, so you don't end up with problems in the future.
    I wouldnt worry about a bad HU just yet, try the above things and if its not working for you THEN have the HU checked out.
    Don't PM me, I'm not here. Find me on SSA or ROE
    No, I won't re-upload the Big3 pictures. Don't ask.
    axel's Avatar
    axel is offline Junior Member
    Jul 2005
    Bullhead
    Icon33 Re: Help wiring 4 channel amp
    Accually man. I have the same exact problem.... its accually common with the 960 and 9600 for the ground to blow... this is the second unit that i had to get and replace for this same reason.. Loud car noise and a constant whinning. I Just took mine apart to see if i could find the problem, but i didnt now i have to take it in. The reason my ground trace messed up is cause i touched a negative and a possitive on my speaker together... Any suggestions guys?
  9. #9
    Prowler573's Avatar
    Prowler573 is offline R.I.P. Gossamer!!
    May 2005
    Northwest Louisiana
    44
    18,522
    Quote Originally Posted by ashaman
    It takes some work, trial & error, and a lot of fiddling around to get it right but it's only a bad idea if you're not willing to invest the install time to get it how it needs to be. I have two sets of components in my car and the imaging is just fine, IMO, tyvm.
    To be honest it was a huge pain in the posterior getting the rear tweets aimed and attenuated right but in the end I found it to be well worth the trouble.
    As for the original poster - it does sound like he's encountered the infamous Pioneer ground trace problem in their recently produced head units. If your head unit and amplifier grounds are good (check these with a multimeter to verify the solidity of the ground connections) then I'd have the HU looked at to see if therein lies your noise problem.
    Refs: [CA.com] [eBay.com]
  10. #10
    axel's Avatar
    Jul 2005
    Bullhead
    Well what exactly is a ground trace?
  1. Best Wiring Setup For 2 Memphis 12's And My System?
    By swank in forum Wiring, Electrical and Installation Help
    Last Post: 01-27-2005, 04:01 PM
  2. wiring components and 4 channel amp
    By DJ FADE in forum General Discussion
    Last Post: 10-24-2004, 07:30 PM
  3. 4 channel amp comparison
    By brandontw in forum Amplifiers
    Last Post: 10-15-2004, 08:28 PM
