Results 1 to 14 of 14
Reload Thread: alt over charging battery??
    paintball9908's Avatar
    paintball9908 is offline Senior VIP Member
    Mar 2003
    Michigan
    30
    302
    JUst curious question, what stops the alt from not overcharging the battery, or can this occur??
    ~My Home Page~
    http://www.cardomain.com/id/ksmutek
    Audio Setup:
    10" Jl audio W7 in H.O. Wedge enclosure ported
    jl audio 500/1 amp
    Stinger 3400 wireing kit
    Alpine CDA-9815 Head Unit
    hoss's Avatar
    hoss is offline imma genius. so **** it!
    Sep 2003
    inside icetee, while he is inside seths sister
    34
    13,810
    Re: alt over charging battery??
    the voltage regulator. and the batteries complete and total lack of ability to charge more than it is designed to
    Mar 2003
    Michigan
    30
    302
    If I replace my alt, is their any electrical system changes that must be made?
    ~My Home Page~
    Audio Setup:
    jl audio 500/1 amp
    hoss's Avatar
    Sep 2003
    34
    13,810
    id suggest the big three to handle the extra current. other than that, no.
    id also suggest upgrading the big three first and see if that helps. a single JL1200 watt amp shouldnt create a massive strain. try the big three first, if you need more look into an alt re-wind. much cheaper than a new alt.
    speedoption's Avatar
    speedoption is offline Junior Member
    Feb 2005
    Hillsboro Texas
    getting a new alt might fix your problem, you might have shorted it out when you did something and it may be overcharging because of that
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    34
    12,794
    5 Post(s)
    Quote Originally Posted by speedoption
    It can't overcharge. It was a what if question. So no a new alt will not fix a problem that does not exsist.
    Quote Originally Posted by Scoobydoo View Post
    Before poking fun at others at least learn to spell. I won't go into all the gammar mistakes!
    Irony?
    Your sig... Im trying to figure out if you think he spelled grammar wrong. Because, he didn't. Irony indeed.
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    If the voltage stays at a safe level...if the voltage increases, then yes, overcharge is a very serious problem.
    Mar 2003
    Michigan
    30
    302
    i can get a 200amp alt, for 200.00, off ebay brand new 1 year warrenty, anyone install one before?? how easy/hard, and other things I need (besides big 3) any changes to computer in car or anything along that matter?
    ~My Home Page~
    Audio Setup:
    jl audio 500/1 amp
  9. #9
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    36
    4,234
    Quote Originally Posted by Jack Frost
    x2 if the regulator is shot and everything is getting 16V, then your in trouble
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
  10. #10
    Logikalliquid's Avatar
    Logikalliquid is offline CarAudio.com Elite
    Oct 2003
    SoVA
    32
    972
    Quote Originally Posted by paintball9908
    Big 3 should be all you need. Definately nothing to do with the car's computer or anything.
    "The only thing we have to fear more than fear itself is the indifference of good men."
    -Boondock Saints
    '98 240SX SE
    US Acoustic 4085 - Crystal SSX615
    US Acoustic 2150 - JL 10W6
    REFs: http://www.caraudio.com/vb/showthread.php?t=94778
  11. #11
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    www.motorcitysuperstore.com
    i got mine form they. they are great guys. alternators are usually just a bolt on piece. i loosened the 'tensioner pulley' and disconnected my old alt via 4 bolts, put the new one in place, re-bolted it on, looped the new belt round the system via the diagram that was on the car in the engine, and tightened the pully back to normal.
    took like 20~30 mins to do because the bolts on the **** thing were huge and long and they took forever to unscrew.
    from 1~10, it was seriously like a 2 or 3.
  12. #12
    Oct 2003
    SoVA
    32
    972
    Quote Originally Posted by req
    What size alternator did you get from them? I asked them if they had 200a alts and they said they no longer make them because thy have had reliability issues with them. I just ordered from DB electrical, another ebay store for <$200.
    -Boondock Saints
    '98 240SX SE
  13. #13
    Feb 2005
    Hillsboro Texas
    No dont go for that alt, thats way to much, go to your local auto zone, or napa, and they will have the alt that u need, or they can order it, i just put a brand new alt in my truck and it cost me $60 with a one year warrenty, the liftime was going to be around $80 but i didnt have the extra 20 bucks at the time and i needed it right then, as far as installing it, altanators are very easy to install, just unplug your battery, release the tension on your belt, by the pulley, and umplug and unbolt everything, then just follow those steps to put it back
  14. #14
    hoss's Avatar
    Sep 2003
    34
    13,810
    big difference between a replacement alt and a HO alt dude...
    auto zone/napa is NOT going to have what he needs...
  1. Battery / Alt question
    By Jeff06 in forum General Discussion
    Last Post: 11-17-2004, 08:58 PM
  2. Alt or Battery?
    By raymondau in forum Amplifiers
    Last Post: 02-04-2003, 12:15 PM
  3. two batteries?
    By buster in forum General Discussion
    Last Post: 01-26-2003, 12:46 AM
  4. charging my battery
    By AScreenName in forum General Discussion
    Last Post: 01-04-2003, 06:48 PM
