Results 1 to 8 of 8
Reload Thread: Can You Hook up 3 subs to 2 amps??
    bisdhawks25's Avatar
    bisdhawks25 is offline Junior Member
    Jan 2005
    Ft. Worth, TX
    18
    OK, right now i am running 4 diamond audio 10" MKII M6 subwoofers at 800watts RMS each, and 1200watts max....The subwoofers are dual 4 ohm, and they are currently wired in parallel so 2 subs are hooked up to each amp at 1ohm....The amps are 2 viper d1200.1 mono channel 1 ohm stable amps...(1200watts rms, 1500max) - It currently sounds good, but i think the subs are lacking some power and could sound better....I was thinking about only running 3 subs instead....I sub wired parallel to one amp, the other sub wired parallel to the other amp, and have 1 voice coil from the 3rd sub to one amp, and the other voice coil to the other amp, that way it will see more power....IS THIS POSSIBLE??? The amps are 1 ohm stable, but i would rather not push them that hard, so this way they feed more power to the subs and they sound better, but they arent being run as hard....Will it work??? I am open to any suggestions!!!! Thanks for your time...
    johnecon2001's Avatar
    johnecon2001 is offline SSA/ROE Super-Møderator
    Aug 2004
    Phoenix, AZ
    35
    5,137
    Re: Can You Hook up 3 subs to 2 amps??
    No it wont work, you would have to set those gains exactly alike, and those amps would have to be putting out the EXACT same thing. Try just running one sub per amp, at 2 ohms each amp. And read the gain setting tutorial in the amps section to see if that helps you at all.
    Don't PM me, I'm not here. Find me on SSA or ROE
    No, I won't re-upload the Big3 pictures. Don't ask.
    Jan 2005
    Ft. Worth, TX
    18
    i dont want to run only 2 subs.....3 at least...any other ideas?? will it work if the gains are exactly the same?? is it harmful to the amps or subs?? thanks
    Aug 2004
    Phoenix, AZ
    35
    5,137
    have you discovered the difference of two versus three? Until you do, I wouldn't attempt to wire three subs to two amps.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    IMHO you are better off the way you are now, with 4 subs (two on each amp). If you take away one sub (and hypothetically assuming your wiring method would work), any increase in power to the other subs wouldn't be enough to make an audible difference. But, on top of that, your amps would be running at a higher impedence, which means the amps would be putting out less power, actually giving each sub less power.
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    37
    6,962
    5 Post(s)
    just buy another amp and wire it the same way the other 2 subs are
    imo
    80
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    35
    873
    If the amps are strappable yes you could run 3 subs with two amps, other than that it is not recommended.
    Jan 2005
    Ft. Worth, TX
    18
    viper d1200.1 mono amps...i dont know if they are strappable or not....anybody else know??? how do you hook up the rca's through a daisy chain?? what inputs and outputs do you use?
  1. subs & amps
    By iwishinew in forum Subwoofers
    Last Post: 09-02-2002, 11:02 AM
  2. Finally Crystal CSe subs review!!!
    By jlman in forum Subwoofers
    Last Post: 08-27-2002, 11:58 PM
  3. new subs and amps
    By EPanther99 in forum Subwoofers
    Last Post: 04-22-2002, 07:32 PM
  4. is it possible to run 2 amps {1for subs and 1 for 4 5x7's} of a 1 farad cap?
    By Bangin-Contour in forum Wiring, Electrical and Installation Help
    Last Post: 03-12-2002, 04:52 PM
