Results 1 to 6 of 6
Reload Thread: Odd question
    Logan4434's Avatar
    Logan4434 is offline Member
    Oct 2004
    Charles Town, WV
    45
    Odd question
    well ive seen enough systems put together in my day to finally do it myself(i deal with the performance of my vehicle my friend does all the sound)(,but hes outa town) for once, i got the powerwire no problem,but the groundwire, does it need a terminal or can i just bolt the wire down, and will it get hot enough to melt platic(plastic tubing like a cm above it)BTW im using 4 guage wiring,running a JLaudio W7 off of a JBL BPx1100.1(ill update my sig with this stuff and a pic of my hip new ride sooner or later)
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Re: Odd question
    As long as its solidly bolted down to a real metal ground...you're good.
    If it gets that hot, you've got bigger things to worry about...like the insulation melting
    Logan4434's Avatar
    Oct 2004
    Charles Town, WV
    45
    Re: Odd question
    well im bolting it into a stock ground i found in the trunk with on really small wire(like 18 guage,main reason im worried about the heat)so it should work,right?
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Re: Odd question
    You're splicing 4awg into the 18awg stock wiring?
    Don't even deal with the stock stuff, take a rat file and expose some bare metal, bolt your wiring into that.
    Logan4434's Avatar
    Oct 2004
    Charles Town, WV
    45
    Re: Odd question
    no im not splicing them together(lol),they would just be bolted to the same ground.
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Re: Odd question
    Go for it.
    Just make sure you've got enough bare metal to make good contact with the 4awg terminal.
  1. Odd Question - What do you use for CD Cases?
    By Apoc in forum General Discussion
    Last Post: 10-12-2004, 08:58 PM
  2. odd question
    By choochooSS in forum Subwoofers
    Last Post: 01-26-2003, 02:45 AM
  3. question about ported boxes
    By crzybob77 in forum General Discussion
    Last Post: 09-17-2002, 10:50 PM
  4. Replies: 5
    Last Post: 08-08-2002, 02:14 PM
  5. Hypothetical warranty question for you guys...
    By wesleysh in forum General Discussion
    Last Post: 08-01-2002, 04:36 AM
