Results 1 to 6 of 6
Reload Thread: Aftermarket CD Player with Factory Tape Deck
    LAOPRINCE's Avatar
    LAOPRINCE is offline Junior Member
    May 2002
    Windsor, ON
    33
    Is it possible to install an aftermarket cd player without taking out the factory deck and use them both???
    indosia's Avatar
    indosia is offline CarAudio.com Elite
    May 2002
    hayward, ca
    593
    You should be able to add a cd changer without removing your factory stereo. This way you can play cds and tapes. I have an equalizer/preamp that has two inputs so you can switch between tape player and cd changer . I think you need to connect it to an amp though.
    chris229's Avatar
    chris229 is offline CarAudio.com Elite
    Apr 2002
    Wilm, DE
    39
    1,107
    you can add a Cd changer the plays on a radio freq from the trunk. It will just sound like FM not a CD.
    indosia's Avatar
    May 2002
    hayward, ca
    593
    I don't think it sounds as bad as radio, but it's not cd quality sound. Why don't you just replace the tape deck with a cd player?
    chris229's Avatar
    Apr 2002
    Wilm, DE
    39
    1,107
    Its impossible for it to sound any better than FM if it's through FM
    indosia's Avatar
    May 2002
    hayward, ca
    593
    If you have an amplifier, you can hook up a discman directly to the amps rca input.
