Results 1 to 4 of 4
Reload Thread: wiring subs to amp
    pinkfloyd_fan69's Avatar
    pinkfloyd_fan69 is offline Junior Member
    Jun 2002
    south boston , va
    37
    Icon33 help!!! need advice on how to wire these subs up
    i have 2 ma audio (DVC in 4 ohm) 12in subs that hold 700watts a piece
    i have on the way an ma audio 1000Watt Mono Block High Performance Amplifier
    1 x 500W Rms
    1 x 1000W Max
    S/N Ratio 95.3dB
    1 Channel Operation
    how should i wire these subs?
    and after wiring, will the amp push these babies?
    right now i have a crunch powerone 600 watt 4 channel amp that is 1ohm stable
    seems like my subs are power hungry. so i have taht ma audio one on the way
    indosia's Avatar
    indosia is offline CarAudio.com Elite
    May 2002
    hayward, ca
    593
    If it can handle 1 ohm, I would wire it in parallell. At 1 ohm they will hit hella hard.
    sagleo's Avatar
    sagleo is offline Member
    Apr 2002
    oregon
    44
    32
    http://www.eatel.net/~amptech/elecdisc/caraudio.htm <<<< GO THERE AND ON THE RIGHT SCROLL DOWN TO SERIES -PARELLEL BASICS.......IT WILL SHOW A PIC OF THE WIRING OF SERIES AND PARALLEL
    2 10s inported 2.0 box mtx 6000series power acoustik gothic series 1500.2amp ,2 mtx 6x9s 2 ,5 1/2 pioneers 300watt craig amp runnin them /pioneer deh245 cd player//////installed in >> geo metro hatchback email @ [email protected]
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,235
    1 Post(s)
    308 Post(s)
    or look below
    series i cant seem to figure a way out to wire 2 subs in series for a mono amp...sorry
    parallel (1ohm)
    series/parallel(4ohm)
