Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Reload Thread: getting the most out of my system
    dkguitarist's Avatar
    dkguitarist is offline CarAudio.com Veteran
    Oct 2004
    Oklahoma City, Oklahoma, United States
    33
    5,013
    i was wondering if anyone could give me advice on how to get the most power out of my amp to push my 2 L7's. i have this rockford amp http://www.rockfordfosgate.com/produ...h%20Amplifiers and i have 2 12" dvc 4ohm L7's wired parellel. each sub is wired to it's own channel. i was wondering how to set my amp or if there's a better way to wire my subs to the amp to get more power or if i should juzt use the gain setting tutorial to set my amp correctly?? any advice i can get would be great. (which the L7's can handle 750 rms as everyone knows). thanks!
    thugpassion's Avatar
    thugpassion is offline Senior VIP Member
    Oct 2004
    South Jersey
    266
    Re: getting the most out of my system
    Are you sure thats the right link, that amp is only 200w. Your really pushing that amp and only giving each L7 capable of handling 750rms+, as you stated, 100w! If thats the amp your really running i would say should really invest in a more powerful amp.
    If you've got the money check out a kicker 1200.1. If your on a tight budget this amp would be perfect http://www.etronics.com/product.asp?...0db&svbname=30. Its rated at 1800rms @ 2ohms and thats probly 14.4v so at 12v it would be exactly 750rms to each sub.
    If youre set on using this amp then I would say to use the gain tutorial to get the max out of that amp.
    97 Altima, Black
    HU: Eclipse CD4000
    Sub: Kicker 04S12L74 in sealed Box
    Amps: ZX750.1 & ZX650.4
    Speakers: SS56.2 comps all around
    Knukoncepts and Tsunami wiring
    Big 3 & 150A alt
    UNDER RECONSTRUCTION - ALL KICKER
    Custom Autosport
    Atco, NJ
    (856) 753-1148
    Auto security, Sound, truck accessories
    feedback - ebay pbnation maldecido33, TheNoodPoopler, guy022077
    Oct 2004
    33
    5,013
    well i originally pulled all this out of my 92 s-10. originally had a jvc hu and a sony 1000w 2 channel amp. got stolen. so i replaced it with this kenwood hu i have in the car now and this rockford amp. also had a rockford punch p1 in a truck box. so everything was pulled out of my truck. i planned on getting more powerful amplifier eventually. but have 2 huge tickets i gotta pay off before i can even think about getting another amp. but thanks for your help. also. juzt out of curiosity how would you bridge these 2 subs to a mono block amp? cuz u have the wires coming out of the terminals on the back of the box, so would you juzt stuff both positive wires in the positve terminal and both negative in the negative terminal or is there a better way??
    jtomsic's Avatar
    jtomsic is offline CarAudio.com Veteran
    Jan 2004
    Washington, Pennsylvania, United States
    32
    5,209
    19
    43 Post(s)
    good god man get a different amp your waisting those subs, if ur not gonna power them right and they are dual 2 ohms sell them to me. u spent all that money on L7s and are powering them with the same power i power my components with.
    Headunit: Pioneer AVH-P2300DVD
    Subwoofers: (2)15" RE Audio XXX(05 model)
    Sub Box: Undecided..
    Sub Amp: Crescendo bc3500
    Speakers: 6.5" RE Audio XXX Components(soon to be 2nd pair in kick panels)
    Speaker Amp: Hifonics HFi100.2(for now...)
    Wiring: 2 runs of 1/0 throughout, XS Power battery in trunk,big 3 done, 270a alt, 1/0 accesories throughout
    Deadner: 75sq ft AT 60mil, 20sq ft Alphadamp
    Security: Crimestopper 2way alarm/remote start
    Oct 2004
    33
    5,013
    well actually they're dvc 4ohms. i got them cuz i planned on getting a better system. i planned on getting a more powerful amp. might use my friend's amp which is "rated" at 1600w max (i highly doubt it, but probly more than this one.) anyways, so back to my question: juzt out of curiosity how would you bridge these 2 subs to a mono block amp? cuz u have the wires coming out of the terminals on the back of the box, so would you juzt stuff both positive wires in the positve terminal and both negative in the negative terminal or is there a better way??
    Oct 2004
    South Jersey
    266
    I dont know of a better way because you want to wire your subs at 2ohms (forget wether thats series or parallel) to get the most out of a 1ohm stable monoblock and using connecters crimped on the speaker wires connect both (+) and both (-) to the corresponding terminals.
    BTW you might actually be hurting those L7s because their min. power is 75w and 'assuming' that amp's ratings are at 14.4v your only giving each sub about 83 overrated watts! just something to think about because I heard you CAN blow your subs by underpowering them!
    97 Altima, Black
    HU: Eclipse CD4000
    Big 3 & 150A alt
    Custom Autosport
    Atco, NJ
    (856) 753-1148
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    When looking at car audio ignore the MAX rating and pay attention to the RMS.
    Max means nothing.
    If one of your buddys say I have a 2000 watt amp. BS ask the RMS rating that is it's true power.
    Just a little info for ya.
    Quote Originally Posted by Scoobydoo View Post
    Before poking fun at others at least learn to spell. I won't go into all the gammar mistakes!
    Irony?
    Your sig... Im trying to figure out if you think he spelled grammar wrong. Because, he didn't. Irony indeed.
    Oct 2004
    33
    5,013
    i know for CERTAIN the amp wouldn't even put out a max of 1600. it's a little cuspid 1600w 4 channel amp i believe. i've only looked at it once. i can't remember seeing an rms rating on the amp but i kno it's WAY overrated juzt cuz it's an off-brand. but when you have a couple of $370 tickets for an accident you caused, it's kinda hard to come up with the money right off hand for a new amplifer....i MIGHT be able to come up with the money in 3-4 weeks after paying off my tickets. but who knows...my friend's amp might be more rms power than my fosgate anyways, so i'll probly temporarily use it til i can get around to helping him install it in his car when i have time. i did all my own wiring. saved me probly over $200 in installation fees. (HU, amp, wiring, and subs). i also plan on getting some component speakers to upgrade the front speakers and get some 6x9's to replace the rear deck speakers (including the blown rear driver speaker). i have a lot more moeny i wanna put into this car but juzt gotta take it one step at a time...but my first step is getting that amp. then use my rf amp to power the components. hehe.
  9. #9
    Oct 2004
    33
    5,013
    Quote Originally Posted by thugpassion
    i've never really seen a monoblock amp bridged to 2 amps before so i'm having a hard time picturing what kinda connector you'd crimp to the speaker wires. are you talking about sumthing like a spade crimp-on connector to slip into the amplifier's output terminals? or like a small ring terminal?
  10. #10
    Oct 2004
    South Jersey
    266
    Actually my neighbor has 2 P.O.S. Dauls bridged to a 300w monoblock but the wires are just screwed to the terminal and looks sloppy (since its two wires in one terminal) and circut city did it like that! I'm saying just crimp some plain old "horse shoe" type connectors that will screw to the terminal. It would be easier to get two connecters in one terminal than two twisted wires. sorry i dont have any pics of the type of connector im talking about but they're very common if i come across a pic i'll post a link since idk how to post pics
    97 Altima, Black
    HU: Eclipse CD4000
    Big 3 & 150A alt
    Custom Autosport
    Atco, NJ
    (856) 753-1148
  11. #11
    Oct 2004
    33
    5,013
    alright. well thanks. yeah i'd think that 2 wires stuffed into 1 terminal would look crappy as opposed to having a connector. that ***** that circuit city did it like that..personally for a cheap job i'd prefer best buy. but like i said i did my own install on this ford escort se. saved myself almost the cost of a new amplifer. but if you don't find one, i'm sure some audio store could tell me or show me or something. but hopefully i'll get that new amp in about 2-3 weeks. hehe. i can't wait to see what these L7's can REALLY do...>.<
  12. #12
    Oct 2004
    South Jersey
    266
    I'm fallin asleep here but heres a link. The connectors im talking about are circled; these are actually 4guauge but you get the picture, just standard connectors; like ring connecters but open in the front.
    And like you I also did all of my own installing to save a good chunk of change. My one L7 sounds pretty d*a*m*n* nice plus i'm only giving it about 600rms and not even done tuning everything (rattles, sound deadner). Once you get a good amp your gonna need a respatory machine to keep your chest from caving in!
    WoW im so tired i forgot to actually put the link in...
    http://us.f2.yahoofs.com/users/80c77...LtxgBBZKx3BQMb
    97 Altima, Black
    HU: Eclipse CD4000
    Big 3 & 150A alt
    Custom Autosport
    Atco, NJ
    (856) 753-1148
  13. #13
    Oct 2004
    33
    5,013
    i appreciate your efforts alot. but that link's not working for me...says i don't have permission to access the site. yeah i also gotta dynamite the trunk and all that jazz for sound deadening. rattles like a mofo right now juzt with what it's being pushed with. also have buzzing from blown rear deck speaker and i think my deck actually rattles with all the bass too....might juzt be the speaker resonance...oh well..maybe i'll disconnect it when i get un-lazy..(yes i kno it's ghetto..:-p). but yeah...if anyone else has any pics feel free to post away. but i think i kno what you're talking about. but i still have 3 or 4 weeks before i can get the amp. good thing i don't have to upgrade my wires again..that was a *****..cuz the one from my truck was too short. so i got a 4awg kit. last one was 8awg. gave it to my friend who i'll eventually help set up his system. so we'll see what happens.
  14. #14
    Oct 2004
    33
    5,013
    ok so i've been looking around for car amplifiers to replace my rf punch amp. i've narrowed it down to a few so i think i'm good to go with that and juzt use my punch amp to power a set of component speakers. but my question is..should i go component speakers all the way around or juzt comps in the front and full-range in the rear or juzt comps in the rear and full-range in the front or what? i juzt wondered what the best way to go with that would be. btw my car is a 1998 ford escort se if that helps. thanks guys.
  15. #15
    Sleeklsc's Avatar
    Sleeklsc is online now CarAudio.com Veteran
    Jan 2004
    Chicago
    6,957
    866 Post(s)
    get comps in the front..
    the rear is up to you..some prefer it some say its pointless....i have mine just cause i have such a big car and my front stage aint the best....down the road i'd get a cheap pair of pioneers or sumtin...
    what amp did you get for the l7's?
    Ref's:1. Midwestcustoms 1.5. Desertheat 2. Mjbailey 3. Terryracing86 4. Sickmint79 5. Untouchable11 6. mattj 7. Ssweet96 8. Kool9accord 9.Kristinspapi10. Kmhogan224 11. Alpine3612 -x3- 12. Vectork39 13. Livinlife 14.Chriscivic 15. Violentraptor 16. Ricky616 17. Bassaddictj 18.orioles26 19.Khail19 20. jak3th3snak311 21. Myjaja 22. Springy101 x2 23. Ali1 24. Privatepastry 25. Plus about 10+ more..
  1. stolen system
    By Rmsanger in forum Subwoofers
    Last Post: 07-11-2005, 03:02 PM
  2. How will my new system compare to the old?!
    By Epitaph to War in forum Subwoofers
    Last Post: 12-06-2002, 11:08 PM
  3. Rewiring my system after the shop butchered just about the whole thing.
    By Beast1284 in forum Wiring, Electrical and Installation Help
    Last Post: 10-25-2002, 01:28 AM
