Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
Reload Thread: HO Alternator, opinions plz.....
    LIGHTBEING's Avatar
    LIGHTBEING is offline CarAudio.com Elite
    Jun 2004
    New Jersey
    872
    Hey guys,
    I'm looking for a HO Alternator for my 00 Acura TL and so far I only found 2 options. The first would be to take my alternator out and get it rebuilt by Ohio Generators to 190 amps for $300. However, I would need to take it out and would probably take about a week til I get it back. Don't think this is really doable.
    The second option is an Alterstart Alternator. Has anyone heard about these? Are they a good reputable company? They have a direct bolt on HO Alt for the TL.
    http://verizonsupersite.com/4alterst...L&catuid=10013
    It's 180 amp Alternator for $300 and an extra $25 for a 4 gauge power wire. Is this required or recommended? Also, is it normal for Alternator to acheive full power at higher RPMs? It says it produces 80 amps @ 800 rpms and 180 @1800 rpms. Is that normal, does that mean I can't play my system loud at a traffic light?
    Any other companies that sell TL Alternators that you know of?
    Any help would be greatly appreciated.
    HU: Kenwood Excelon DDX-7015
    Sub Amp: US amps MD2D
    Sub: 12" RE XXX
    Comp Amp: SS Reference 700s
    Comps: CDT HD-62
    Rearfill: CDT CL-6X
    Box: 2.5 cuft after displacement
    Kinetik HC1800
    OG 185a HO Alt
    100 sq ft eDead
    Custom Trunk
    loserpunk's Avatar
    loserpunk is offline hapbahdasindot
    Jan 2003
    Elkhart, Indiana
    31
    1,881
    39
    Re: HO Alternator, opinions plz.....
    i've never dealt w/ either of those companies....i simply found a local place that would build one w/ a warrenty for 1$ per amp....i'd suggest running 2ga or 0ga for any alt over 150amps.....you can grab either on ebay or www.weldingsupply.com
    Email - [email protected]
    REFS -
    rockingchair69
    tirefryr
    magick_man
    cjj2d
    ssj2xxgotenxx
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    33
    37,876
    go to www.excessiveamperage.com. he usually has good prices on alts. it is normal for alts. to have lower amps at an idle. idealy you should look for one at around 100 amps at idle.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    30
    3,509
    YOu said that you can get one from Ohio Generator, cause i cannot find a website or phone number. I was looking at getting one from them. Could you post it.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    LIGHTBEING's Avatar
    Jun 2004
    New Jersey
    872
    Thanks guys for all the great info. Anyone else know any other options?
    monte_carlo97, Ohio Generators number is 330-875-6677, ask for Tom
    or Gus. And if you want you can mention Austin's alternator upgrade for the TL. He is the one that contracted them to do the rebuild. Say he is a friend of a friend or something. If you have the time for a rebuild, Ohio Generators are the way to go.
    Sub: 12" RE XXX
    Comps: CDT HD-62
    Rearfill: CDT CL-6X
    Kinetik HC1800
    OG 185a HO Alt
    100 sq ft eDead
    Custom Trunk
    LIGHTBEING's Avatar
    Jun 2004
    New Jersey
    872
    Hey Guys/loserpunk,
    I just talked to a guy over at Alterstart and they said they recommend 4 gauge power cable for the Alt unless you are running it more then 6 ft. The Power cable gets run to the battery correct? So mine would be less then 2 feet away. Should I still get a 2 gauge or stick with what they recommend? I checked out www.weldingsupply.com and thaey are considerably cheaper. for 2 gauge it is the 2/0 correct? It's says it's 1.69 per ft. Should I get like 3 feet to play it safe?
    Thanks
    Sub: 12" RE XXX
    Comps: CDT HD-62
    Rearfill: CDT CL-6X
    Kinetik HC1800
    OG 185a HO Alt
    100 sq ft eDead
    Custom Trunk
    LIGHTBEING's Avatar
    Jun 2004
    New Jersey
    872
    http://www.weldingsupply.com/cgi-bin...F:OR:terms::PA
    By this grid I should run a #2 gauge for a 180a less then 50 ft, no? So that's not the same as 2/0? what is the difference?
    Sub: 12" RE XXX
    Comps: CDT HD-62
    Rearfill: CDT CL-6X
    Kinetik HC1800
    OG 185a HO Alt
    100 sq ft eDead
    Custom Trunk
    phrozen5100's Avatar
    phrozen5100 is offline CarAudio.com Elite
    Jun 2004
    Indiana
    572
    Ummm...2/0 is like twice as big as 2 ga, so that #2 ga. would work fine. You could always try to contact Dominick Iraggi for a HO alt, he has a real good reputation on this forum :-).
    Refs: 96civ, desertheat, baseballer1100, LowEndTheory, Belunt
  9. #9
    diminishedpower's Avatar
    diminishedpower is offline I Like Chicken
    Mar 2004
    Iowa
    933
    yeah i got my ho alt from dominick, a 240 amp alt, got it to me real quick, i havent had time to install it because i want to buy a yellow top before i install but i have no doubts it works great
    05 Scion tC
    Subs = 15 inch power hx2 in 3.5 cu/ft at 32 hz
    Sub amp = Cadance ZRS-9
    FOR SALE:
    Ford BNIB 240 amp alt, only 200 shipped
    Refs: T9X, spoonraker
  10. #10
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    I'd suggest either
    www.mean-green.com (where i got mine! great customer service and quality) 2 year 300,000 mile warranty
    or
    Both are great! Ohio Generator is good also...BUT i would stay away from alterstart...bad news...bad reliability.
    Tell mean-green Rocky Gentry sent you...they're great. peace
    NG
    http://crunktimes.com/ct/
    nG - BSEE
  11. #11
    LIGHTBEING's Avatar
    Jun 2004
    New Jersey
    872
    Quote Originally Posted by phrozen5100
    So #2 Gauge is what I need then, What gauge would I need from the battary to the amps? Is that what 2/0 is used for?
    And I don't think Iraggi makes anything for the Acura TL and I read that there was some shady behavior with Dominick? And that people were waiting months for their Alternators and getting no response from him. I really can't deal with that. Been there before and Although the product was the best, wasn't worth the lousey customer service.
    Sub: 12" RE XXX
    Comps: CDT HD-62
    Rearfill: CDT CL-6X
    Kinetik HC1800
    OG 185a HO Alt
    100 sq ft eDead
    Custom Trunk
  12. #12
    LIGHTBEING's Avatar
    Jun 2004
    New Jersey
    872
    Quote Originally Posted by ngsm13
    I'd suggest either
    or
    NG
    Hey man,
    I was looking into mean green but I don't think they make anything for my car, I guess it wouldn't hurt to call them though.
    I called excessive amperage and shot them an email and nothing yet, maybe I'll follow up with them too.
    Now about Alterstart, what kinda bad things did you hear about them? I was really considering them.
    Sub: 12" RE XXX
    Comps: CDT HD-62
    Rearfill: CDT CL-6X
    Kinetik HC1800
    OG 185a HO Alt
    100 sq ft eDead
    Custom Trunk
  13. #13
    Strecker25's Avatar
    Strecker25 is offline Better than everyone
    Feb 2004
    Rochester, NY
    30
    989
    I'd suggest either
    or
    NG
    can i ask what your experience with them is? im curious because they quoted me for a 180amp for 179.99 with a lifetime warranty and that is quite a deal i think
    Panasonic CQ-HR1003U
    Twin Diamond Audio M6 12D4's
    3.2Ft^3 @33hz
    Viper Audio d1200.1
    Diamond Audio M651 5.25" components
    Profile Clarus CL800
    200amp alt, big3
    2 Gallons of eDead v3 ( Group Buy )
    40sqft eDead V1se
    20sqft Dynamat extreme
    Pictures of the setup
    Video of the M6's
    All in a 94 Lumina
  14. #14
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    Quote Originally Posted by Strecker25
    LMAO, which company...i mentioned three! peace
    NG
    nG - BSEE
  15. #15
    Strecker25's Avatar
    Feb 2004
    Rochester, NY
    30
    989
    lol sorry i meant to change the quote so it narrowed it down to what you said about alterstart...so yea them they quoted me 179.99 for 180amp with a lifetime warranty
    3.2Ft^3 @33hz
    Viper Audio d1200.1
    200amp alt, big3
    40sqft eDead V1se
    Video of the M6's
    All in a 94 Lumina
  1. In Need of a HO alt PLEASE HELP
    By BlkMica_03 in forum Wiring, Electrical and Installation Help
    Last Post: 10-27-2004, 06:29 PM
  2. ho...ho...ho...HOLY CRAP!
    By d audio 450 in forum Amplifiers
    Last Post: 01-04-2003, 08:45 PM
  3. Where can I get JL HO Box with 2 W'3s ?
    By beachboy016 in forum Subwoofers
    Last Post: 10-02-2002, 06:17 PM
  4. Q about the JL HO Wedge box...
    Last Post: 09-29-2002, 12:56 AM
  5. HO Box VS. Pro Wedge
    Last Post: 09-15-2002, 08:41 PM
