Results 1 to 11 of 11
Reload Thread: No sound from subs!!
    Jacobs's Avatar
    Jacobs is offline JIMMY GO BOOM BOOM
    May 2002
    Kingsville, Ont. Canada
    34
    253
    A few weeks ago I was crusin in my car with my subs pounding (2 pioneer IMPP 1000W 12") The amp I had was a peice of crap. It was a power acoustic 600W 2 channel. the subs crapped out. So I checked all the fises power and all that other stuff and it looked all good so i figured I blew my amp. So today i went out and bough a JL audio 500/1 monoblock sub amp. hooked it all up turned my car on and no sound! I had power going to my amp but just no sound So i figured it was something behind my head unit (lose remote wire or something). Checked that everything looked fine. ANy advice on what too look for next? Is it possible my head unit (pionner primer DEH-P630) isn't putting signal out to the remote wire?
    imral3's Avatar
    imral3 is offline Sponge Bob Rules !!!!!
    Jan 2002
    NJ
    50
    526
    if you have power to the amp then it is not the remote wire. check your rca cables as well as the wiring for the subs themselves.
    good luck and good listening!
    L8r
    Jacobs's Avatar
    May 2002
    34
    253
    I checked the RCA wires they were fine. With the remote wire i totally disconnected it form the HU and the power light still stayed on. I am so lost!
    Loud music is good... Loud music that is clear is better
    ______________________________
    2002 GMC Jimmy
    hu - pioneer primer DEH-P630
    Sub amp-JLaudio 500/1
    Speaker Amp-Pioneer GM-X564
    subs-pioneer Primer TS-W1241DVC
    6X9's-Pioneer TS-A6985
    pioneer primer TS-C504 component speakers
    imral3's Avatar
    Jan 2002
    NJ
    50
    526
    you need to do everything you can think of to test your H/U. connect to a friends amp and see if it works. check the fader control. try new rca cables. these are not in the best or easiest order but are just a few things i can think of at 1:52 am.
    L8r
    Jacobs's Avatar
    May 2002
    34
    253
    Ok this is what i've done so far. I just took the remote wire and hit it againts the remote comming out of the hu. put it together amp turned on took it off amp turned off, so I know its not the remote. tried a different set of RCA cables still nothing so I know it's not the cables. Tried the subs in my friends car they worked fine so i know it's nothign with the amp or subs, anything else anyone can think of or think I should just give up and bring my HU back (it's still under warentee, so I don't have to worry bout money)
    2002 GMC Jimmy
    spunkymanker's Avatar
    spunkymanker is offline Junior Member
    May 2002
    Klamath Falls, OR
    40
    19
    no sound
    here's how I've always tested things like this - get a portable CD-player (like a discman) and get a stereo headphone to RCA cable, then connect that portable directly to your amp. If that doesn't work, it's not your head unit. If that works, then it's your head unit, or the RCA's coming back from it.
    imral3's Avatar
    Jan 2002
    NJ
    50
    526
    if you are still under warranty... return that puppy!!!!
    L8r
    Jacobs's Avatar
    May 2002
    34
    253
    Ok i tried the portable cd player thing and it didn't work, is it possible it could be a bad ground? The amp gets power though, wouldn't it just not work at all if it were a bad ground??
    2002 GMC Jimmy
  9. #9
    Jacobs's Avatar
    May 2002
    34
    253
    Another quick question... right now I have my capacitator, amp and something else (i think it's my tail lights) hooked up to the same ground, could that be the problem? is everything supposed to have a seperate ground?
    2002 GMC Jimmy
  10. #10
    Benny's Avatar
    Benny is offline Junior Member
    May 2002
    Portland OR
    32
    27
    do these....
    1. i had the same problem.... first hook up jsut the amp.. to a ground nothing els...
    2. go to your house and make sure your h/u is ok buy hooking up your rca to a house stereo...
    well i will think of more..
    H/U RF 9200
    AMP
    Orion 100.2
    4X400 Rockfoadfasgate ( tradeing)
    2x Orion XTR 12
    2x 6 1/2 Mb Quatrs
    2x 6 1/2 INFINITYperfects
    2x 4" INFINITY perfects
  11. #11
    May 2002
    atlanta,Ga.
    35
    There is a great repair place in atlanta called high-end car audio repair center their address is 1919 metropolitan ave atlanta Ga. 30315 they have very fast and precise service i highly recommend them. their # is 404-763-2005 or 770-473-6556
    AUDIOPHILE4LIFE
    ps their prices are great !!!
