Results 1 to 2 of 2
Reload Thread: 1986 Chevy Caprice Classic
    UrbanSounds's Avatar
    UrbanSounds is offline Member
    Aug 2004
    Orange County, CA
    106
    Whats up guys.
    I need to install a headunit into this car and was wondering how to take out the stock stereo. I tried looking for any screws or snaps, but had no luck.
    anyone know whats up.
    Thankx
    KaeZoo's Avatar
    KaeZoo is offline CarAudio.com Elite
    May 2004
    Grand Rapids, MI
    1,103
    Re: 1986 Chevy Caprice Classic
    It's a pain to take apart. The heater control assembly and radio are attached together, and it's not just a matter of unplugging harnesses to pull it out.
    You should find 2 screws above the heater, and 2 more inside the ashtray cavity after you remove the ashtray. Removing them allows you to pull the whole assembly a few inches out of the dash, but the cables at the back of the heater controls will hold you up. If you look behind the glove box, you will find a point where one of the heater control cables is anchored; you can release it to give yourself some more room.
    Once you have the whole setup pulled far enough from the dash, look on the BACK side to find the 4 screws that hold the radio and air conditioner controls together. If you can get a socket or nutdriver into position to remove these, you should then be able to unplug the radio and remove it.
  1. factory chevy dual batteries/ non-diesel
    By buster in forum Wiring, Electrical and Installation Help
    Last Post: 12-16-2002, 03:45 PM
  2. Install Kit For '91 Chevy
    By natedog in forum Wiring, Electrical and Installation Help
    Last Post: 08-24-2002, 06:04 PM
  3. sub help for big chevy
    By b bumble in forum Subwoofers
    Last Post: 06-09-2002, 08:41 PM
  4. 2001 Chevy Blazer
    By Tryin2bump in forum Wiring, Electrical and Installation Help
    Last Post: 01-21-2002, 10:27 PM
  5. 01 chevy ext cab box for underseat !
    By jrmax in forum Subwoofers
    Last Post: 01-19-2002, 07:03 PM
