Results 1 to 3 of 3
Reload Thread: 1992 GMC Sierra Radio Install
    mckeller's Avatar
    mckeller is offline Junior Member
    Sep 2004
    Anywhere USA
    Hey guys,
    I am looking to recess my new Alpine by a couple of inches so I can make a cover to have a stealth install Using the factory dash in the middle of the truck. My question is has anyone ever done this and or have pics so I could get an idea. And if you have what did you use to mount it.
    Thanks
    Slody4Futbol's Avatar
    Slody4Futbol is offline CarAudio.com Elite
    Jan 2004
    Jackson, MS
    33
    1,207
    Re: 1992 GMC Sierra Radio Install
    have u bought the kit already for the truck? the mount extends the radio part out about 2 inches because the dash is VERY shallow behind the opening... there is a piece of metal that is in the center behind the factory radio... i would just buy the kit... install the radio... and try 2 make a cover for it then...
    Been out of this for a longgg time...
    Einzee's Avatar
    Einzee is offline Service Professional
    Aug 2004
    Norwalk, CA
    44
    344
    4 Post(s)
    Yes the piece of metal behind the radio can be removed. But if I remember correctly there is A/C ducts that are still in the way. Removing the piece of metal only provided more clearance for the RCA's and other wires for H.U.
    Stupid questions make more sense than stupid mistakes!
    It is best to remain silent and be thought of as stupid, rather than opening your mouth and removing all possible doubt!
    Quote Originally Posted by Twistid View Post
    Try taking the positive wire from your battery and run it to the engine block, see if that should fix things...
    Quote Originally Posted by PaulD View Post
    THE FUSE AT OR NEAR THE AMP PROTECTS THE AMP. WIRES DO NOT NEED "PROTECTING" WITH A FUSE SINCE THEY ARE NOT POWER PRODUCING DEVICES.
    Quote Originally Posted by shake this View Post
    Which one sounds better (short small diameter or long large diameter)?
  1. GMC Sierra System
    By Spaceboy464 in forum General Discussion
    Last Post: 09-27-2004, 11:37 AM
  2. 1990 GMC Sierra???
    By junocdx in forum Wiring, Electrical and Installation Help
    Last Post: 01-24-2003, 03:07 PM
  3. Install In Vehicle 93 GMC Suburban
    By avw241 in forum Wiring, Electrical and Installation Help
    Last Post: 04-20-2002, 03:42 PM
  4. 96 GMC Sierra
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 03-31-2002, 05:36 AM
  5. how to install crunch amp to factory radio
    Last Post: 03-01-2002, 02:33 PM
