Results 1 to 4 of 4
Reload Thread: Wiring 3 Amps / REM Wire and Battery Questions
    omnipseudo's Avatar
    omnipseudo is offline .4Wheelin Sound Addict
    Apr 2004
    Vail, Colorado
    31
    50
    Hey, im wiring up 3 amps and 5 subs for a big system in a parade but I have a few qs.
    #1 : Idealy each amp will run off its own battery, situated right next to it. Thing is, the batterys wont be plugged into the car, just there. We tried wiring an amp up like this, but it doesnt work. Ive tried the ground to the negative terminal and to a ground point, nothing. The REM wire works, as the standby light comes on...but no sound. RCAs are plugged in...just wondering if i need something else to be able to run the amp off the stand alone battery...
    #2 : Can i daisy chain the REM wires from the HU to amp#1, to amp#2 then amp#3? Or do I need to get some type of small distro block?
    Thanks in advance for the advice!
    2000 Jeep Wrangler Sport
    Tweets : In progress
    Speakers : 2 Alpine 4x6 SPS 2-Way and 2 Boston 5.25" RallyX
    Head Unit : Sony CDX-F7005X
    Amp : Boss 700w 2chan, 2ohm stable (Lookin for a new one)
    Subs : 2 10" Kicker Comp VRs
    Box : Sealed Custom QLogic
    Mind_nl's Avatar
    Mind_nl is offline www.bugfix.nl
    Jul 2002
    The Netherlands
    114
    Re: Wiring 3 Amps / REM Wire and Battery Questions
    Amp directly on a battery should work, just hook up the plus and remote of the amp to the plus of the batt and the ground to the minus... However I don't really think it is a good idea to hook your amps up like that, there can be a potential difference in the negative connections, ideally you should connect the negative of all batteries to the ground of the car. Now for the remote I would not put more then 2 amps daisy chained on the remote wire, you should put in some sort of delay on the 3rd amp to prefent all 3 amps switching on at the same time, pulling to much power thru the remote wire
    ~: WARNING: Objects in mirror are more stable than they appear :~
    www.bugfix.nl currently working on: www.explicitaudio.nl
    omnipseudo's Avatar
    Apr 2004
    Vail, Colorado
    31
    50
    thanks for the reply - so with the batteries, if i run the plus and rem wires right to the battery when its go time, all the amps will be on...thus eliminating the need to run a rem from the hu, right? and with the common ground, just run a wire from all the neg battery terminals to the same grounding spot? thanks again for the replies
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    You will need to have all the negatives tied together if you intend to run common RCA's and remotes to them. Ground each battery negative to the car body and you should be good.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. Wiring 3 amps, 5 subs and 2 tower speakers to a car?
    By omnipseudo in forum Wiring, Electrical and Installation Help
    Last Post: 09-22-2004, 12:25 AM
  2. Cheap power wire...
    By Savant in forum Wiring, Electrical and Installation Help
    Last Post: 01-05-2003, 10:16 AM
  3. wire size FYI
    By Steven in forum Wiring, Electrical and Installation Help
    Last Post: 10-23-2002, 08:31 AM
  4. 2nd battery wiring help
    By phillupz in forum Wiring, Electrical and Installation Help
    Last Post: 09-23-2002, 09:29 AM
  5. Two Batteries. 2 amps, adn two questions
    By sforget in forum Wiring, Electrical and Installation Help
    Last Post: 07-27-2002, 02:15 AM
