Results 1 to 3 of 3
Reload Thread: where do i hook up my remote wire for my amp
    audiobahnboy's Avatar
    audiobahnboy is offline Junior Member
    Sep 2004
    roseville, mi
    ok i have a rockford 1600 watt 2 channel amp and 2 12" audiobahn special series subs i think i have everything hooked up right except my remote wire. i have it ran to the radio fuse in my fuse panel and after listening to it for awhile it blows a fuse and my radio and my amp shut off can you tell me where to hook up the remote wire and why undefinedit keeps blowing fuses
    skeptikal's Avatar
    skeptikal is offline Hold the wheel and drive skeptikal is a Supporting Member of the forum!
    Jul 2004
    Indiana, US
    4,066
    22 Post(s)
    Re: where do i hook up my remote wire for my amp
    why is it not wired to your deck? if it goes to your deck the amp will turn off when you turn your car off. honestly i have no idea why it keeps blowing the fuses. but im sure someone on this forum does. the only thing i can tell you is where the remote goes.
    In the wiring harness for your headunit, there should be a blue (or maybe yellow) wire that is your remote wire. you can splice the remote fire from your amp into it and use electrical tape (ghetto rigged).
    okay here's where the remote wire should go.
    Deck.
    amp.
    2005 Dodge Ram Quad Cab
    Pioneer DEH-80prs
    Image Dynamics X-65
    Image Dynamics XS-28
    PPI 900.4
    Wolfram 1500.1
    Sundown Audio SA-12 D4 (x2)
    Noico deadener
    NVX wiring
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Hooking the remote wire to your radio fuse should work without blowing any fuses. The only bad thing is your amp will be on all the time and drain your battery. The current required for remote is usually very small, less than 1/2 amp. Either something is wrong with the amp or the other stuff on that fuse circuit is blowing it. If you run the remote wire to the correct wire (usually blue) on your head unit the power still comes through the radio fuse and it'll probably blow again anyway unless you figure out what's causing it.
    Radio fuses should be at least 10 amps. Is yours?
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. Replies: 13
    Last Post: 06-11-2010, 03:30 PM
  2. How do you hook up a blade amp to 2 8w6s
    By tomz in forum Wiring, Electrical and Installation Help
    Last Post: 12-19-2002, 11:47 AM
  3. how to hook up a amp
    By adam in forum Wiring, Electrical and Installation Help
    Last Post: 07-08-2002, 01:08 AM
  4. 3 HE2's on a MONO Amp -> HOW TO WIRE?
    By rayan66 in forum Subwoofers
    Last Post: 06-21-2002, 11:56 AM
  5. Replies: 1
    Last Post: 04-18-2002, 05:38 PM
