Results 1 to 4 of 4
Reload Thread: Easy wiring a component set question
    bama350z's Avatar
    bama350z is offline Senior VIP Member
    Aug 2004
    Alabama
    40
    372
    Does anyone know of an EASY descriptive website of how to hook up an amp to a component set with crossovers...i have 2 empty channels in my amp and was going to add another component set in the rear...amp is already set up running one set of components in the front....but i want to do the rear component set myself.........ppi a404.2 amp with 2/4 channels used and a second set of diamond audio s600s components to go in the rear fill.. THANKS!!
    johnecon2001's Avatar
    johnecon2001 is offline SSA/ROE Super-Møderator
    Aug 2004
    Phoenix, AZ
    35
    5,137
    Re: Easy wiring a component set question
    Well,
    I don't have an actual website... but I can walk you through the install.
    You need to run another set of RCA's from your HU to the other two channels on the amp. Assuming the amplifier is located in your trunk or hatch, just run new speaker lines to the rear speakers. Use no larger than 10ga. Thats pretty much it, you may want to futz with the settings to determine what sounds best. Let us know if you need anything else.
    Don't PM me, I'm not here. Find me on SSA or ROE
    No, I won't re-upload the Big3 pictures. Don't ask.
    bama350z's Avatar
    Aug 2004
    Alabama
    40
    372
    thanks, for some reason i didnt think i had to go back into the HU...i thought i caould run new wires from the amp directly to the spaekers, since the amp is already hooked up to a pre-existing set of components..
    DFW40's Avatar
    DFW40 is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    You can use a "Y" adapter on the RCA's to give input to channels 3 and 4 if that is neccessary. Some multi channel amps can run on one set of RCA's. This might lower your input signal voltage which you can make up for on the amp's input sensitivity.
  1. Wiring Question
    By Hammy in forum Wiring, Electrical and Installation Help
    Last Post: 11-08-2002, 05:30 PM
  2. Replies: 2
    Last Post: 08-16-2002, 01:09 PM
  3. Replies: 1
    Last Post: 08-15-2002, 12:48 PM
  4. what a component set?
    By john_1984 in forum General Discussion
    Last Post: 07-11-2002, 12:53 PM
  5. Wiring Subs (easy question)
    By ToadChuck in forum Wiring, Electrical and Installation Help
    Last Post: 01-12-2002, 12:22 AM
