Results 1 to 9 of 9
Reload Thread: need to wire an re se to an mtx 6500d
    Doberdad's Avatar
    Doberdad is offline CarAudio.com Elite
    Jan 2003
    gb wi
    32
    650
    link for the amp(specs)
    http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
    the sub is dvc 4ohm
    thanks
    2006 VW Jetta 2.5L 6Speed Manual. INEEDSOMEBASSasap
    system:
    In Progress(new vehicle)
    WTB
    jl w3 or jl w6 series sub
    jujumantb's Avatar
    jujumantb is offline Duke of Earl
    Jun 2004
    Madison, Wi
    31
    3,417
    Re: need to wire an re se to an mtx 6500d
    Wire both + terminals to the + on the amp, and both negative terminals to the - on the amp. Basic parallel wiring to get the 2 ohm load you need.
    edit:
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    if you want a DVC4 ohm sub to run at 2ohms, link all + and - VC together with a wire, and then hook opposite +\- to the amp.
    seen here
    req's Avatar
    req
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    ****it. got beaten. but i have a diagram
    anywho, my 10" re SE is bumping QUITE HARD in its 1.2cubic foot enclosure @37hz (well, its not 1.2 yet, nor is it 37hz yet, but it hits really hard none the less)
    PORT IT! AND TAKE PICTURES!
    Doberdad's Avatar
    Jan 2003
    gb wi
    32
    650
    so i should only hook it to the +and - on one of the amps two outputs. what i mean is the amp has a + and neg. for one sub and a + and - for another sub. do i use the + on one and the - on the other?
    system:
    WTB
    req's Avatar
    req
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    it said mono,
    so go ahead and bridge the two channels lLIKE THIS
    thats my amp, and its mono with '2 channels' i believe they do this because if you have a 4ohm load, you hook it to channel 1, and a 2 or 1 ohm load- you bridge 1 and 2. makes it easy to wire (i think)
    so bridge just as that picture is, and you should be fine. do you know what the voice coil configuration is on your sub? dual voice coil 4ohm? dual voice coil 2 ohm? if its 2 ohm (and this is possible), then your amp might melt thru your trunk and into your gastank blowing your car into oblivion.
    na, jk. the amp will prolly turn off- or break.
    so find that out for sure.
    req's Avatar
    req
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    it said mono,
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    31
    3,614
    Quote Originally Posted by req
    it said mono,
    thats mono amp, the channels are just wired in parallel inside the amp. It doesnt have 2 channels
    Just wire the +s together, -s together, make one run to the amp.
  9. #9
    likuidslider603's Avatar
    likuidslider603 is offline Junior Member
    Jun 2007
    ME and NY
    Hey, I have a Jensen VM9510 in dash dvd player too. I am tryin to install amp and subs but i dont think that the rca's are right. seeing as you hooked it up, which RCA outputs did you use from the dvd player. Thanks alot
  1. Cheap power wire...
    By Savant in forum Wiring, Electrical and Installation Help
    Last Post: 01-05-2003, 09:16 AM
  2. Confused on wiring 2 dvc JL subs to my mtx 6500d
    By highfiveforyou in forum Amplifiers
    Last Post: 03-01-2002, 09:41 PM
  3. wiring a MTX 6500d
    Last Post: 02-11-2002, 04:05 PM
  4. MTX 6500D
    By <GotBass?> in forum General Discussion
    Last Post: 01-08-2002, 01:55 AM
  5. MTX 6500D CHEAP! PLUS EXTRAS
    By tenchi300 in forum General Discussion
    Last Post: 12-18-2001, 11:37 PM
