Results 1 to 6 of 6
Reload Thread: Alpine 9835 Memory resets itself after ignition is turned off.
    Drag0na5h's Avatar
    Drag0na5h is offline Junior Member
    Sep 2004
    Sacramento
    Icon32 Alpine 9835 Memory resets itself after ignition is turned off.
    I just got an Alpine 9835 headunit and I installed it using the 12V power from the wiring harness. The problem is that when I turn my ignition off and turn it on again, the deck loses all the settings that I put into it and resets completely. I wired the yellow power wire and the red ignition wire (from the headunit) both onto the 12V power wire from the wiring harness. If anyone has a suggestion please tell me; I would greatly appreciate it.
    boister77's Avatar
    boister77 is offline CarAudio.com Elite
    Dec 2003
    SoCal
    31
    824
    Re: Alpine 9835 Memory resets itself after ignition is turned off.
    i believe the yellow wire should go to a constant 12v source and the red wire is the remote/ignition wire.
    www.realmofexcursion.com: Free Hosting for Videos, Pics, Audio, and more!
    forum.realmofexcursion.com: Another car audio forum.
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    32
    4,234
    i don't know i think red is constant 12v, and yellow is switched 12V. either way they don't both go to the same place. look in your instruction book, or the web site or somthin.
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
    stalephotograph's Avatar
    stalephotograph is offline Senior VIP Member
    Aug 2004
    danville, ky
    198
    yea you shouldnt have wired them together. yellow is constant 12v and red is ignition 12v. i had to do this for a bit when i got my alpine cda 9823 b/c a fuse was blown in my fuse panel. but yea yellow to yellow red to red. never wire together.
    My Feedback Thread
    My Car Domain
    1998.5 Audi A4 1.8T
    Headunit: Alpine CDM-9823
    Highs/Mids: Diamond Audio D3 Comps and D3 2-ways
    High/Mid Amp: Diamond Audio D5 300.4
    Sub: Resonant Engineering SE 12" in a 2.3 cu ft slot port tuned to 32hz
    Sub Amp: Diamond Audio D5 1200.1
    References:
    Bought From: LeX, redphoenix
    boister77's Avatar
    Dec 2003
    SoCal
    31
    824
    you can wire them together if you want your hu to tun on/off independent of your ignition. right now i have both my yellow and red wire connected to constant 12v power soucre so i can operate my system without my keys in the ignition. also, this reminds me to remove my face plate since the hu will still be on whenever i turn off the ignition.
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    31
    2,811
    Also, you have to save the settings for the 9835 if you want the deck to keep them when you shut it off. Look in the manual to see how to do it.
  1. ALPINE CDA-7893 vs PIONEER DEH-P9300 vs CLARION DXZ825
    By nick310 in forum General Discussion
    Last Post: 09-05-2002, 01:22 PM
  2. Alpine VS. Pioneer...
    By ßûmþ_§üm±hîñ in forum Subwoofers
    Last Post: 03-03-2002, 06:34 PM
