Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: side rails Vs under carpet
    jb2xx's Avatar
    jb2xx is offline I love asian babes!!
    Sep 2004
    Los Angeles, CA
    99
    Icon32 side rails Vs under carpet
    Wazzup gang!
    I want to know what is everybody's personal preference when it comes to deal with the wiring. Do you simply remove the side rails or do you strip the entire car? I was advised when I did my car, to do a better job is to strip the car & run wiring under the carpet.
    Most auto sound shops out here like to just remove the side rails & do it that way.
    2004 Honda Civic LX
    Alpine CDA-9830
    Kicker KX400.1
    Kenwood KAC 8401 (60wx4)
    RF P310D4 (400W-rms)
    RF FRC4206U (6 1/2) 2 pairs
    RF Wiring
    Big 3 Upgrade
    johnecon2001's Avatar
    johnecon2001 is offline SSA/ROE Super-Møderator
    Aug 2004
    Phoenix, AZ
    35
    5,137
    Re: side rails Vs under carpet
    just pull a bit of carpet up and fish the wire through, not a big job, and it can be easily hidden after the install.
    Don't PM me, I'm not here. Find me on SSA or ROE
    No, I won't re-upload the Big3 pictures. Don't ask.
    jtomsic's Avatar
    jtomsic is offline CarAudio.com Veteran
    Jan 2004
    Washington, Pennsylvania, United States
    32
    5,209
    19
    43 Post(s)
    i just pull the sides up and push it under the carpet, seems like a lot more work for the same thing to pull strip the car down.
    Headunit: Pioneer AVH-P2300DVD
    Subwoofers: (2)15" RE Audio XXX(05 model)
    Sub Box: Undecided..
    Sub Amp: Crescendo bc3500
    Speakers: 6.5" RE Audio XXX Components(soon to be 2nd pair in kick panels)
    Speaker Amp: Hifonics HFi100.2(for now...)
    Wiring: 2 runs of 1/0 throughout, XS Power battery in trunk,big 3 done, 270a alt, 1/0 accesories throughout
    Deadner: 75sq ft AT 60mil, 20sq ft Alphadamp
    Security: Crimestopper 2way alarm/remote start
    stalephotograph's Avatar
    stalephotograph is offline Senior VIP Member
    Aug 2004
    danville, ky
    198
    for the several cars ive installed audio for, i just simply run the wires under the side rails. its fast and simple. plus if you upgrade anytime soon, you wont have to take out the seats and what not. its better than some people i know who ran thier wires under the car onto the frame b/c they thought it was a much safer way. i dont think having your muffler burn through your power wire and maybe a spark to your gas tank is safe lol.
    My Feedback Thread
    My Car Domain
    1998.5 Audi A4 1.8T
    Headunit: Alpine CDM-9823
    Highs/Mids: Diamond Audio D3 Comps and D3 2-ways
    High/Mid Amp: Diamond Audio D5 300.4
    Sub: Resonant Engineering SE 12" in a 2.3 cu ft slot port tuned to 32hz
    Sub Amp: Diamond Audio D5 1200.1
    References:
    Bought From: LeX, redphoenix
    jtomsic's Avatar
    Jan 2004
    32
    5,209
    19
    43 Post(s)
    wouldnt the wire just ground out if ur insulation melted off and was on the frame?
    Aug 2004
    danville, ky
    198
    probably if it were grounded correctly. but im just saying if it were to spark and hit the gas tank then it wouldnt be so pretty.
    My Feedback Thread
    My Car Domain
    1998.5 Audi A4 1.8T
    References:
    Aug 2004
    Phoenix, AZ
    35
    5,137
    if you put it under the side rails you risk premature wire failure... from people stepping on it and stuff. Your going to be way happier with yourself if you go under the carpet. Also the thing about side rails.. not all of them come out easy, I've broken off so many plastic clips that I didn't see, and then I had to go get a new part to replace it.
    On another note, you have nothing to worry about with wire melting IF YOU USE THE RIGHT GAUGE OF WIRE FOR YOUR SYSTEM. When in doubt, go one size thicker.
    clarity413's Avatar
    clarity413 is offline Senior VIP Member
    May 2004
    Bakersfield, CA
    242
    What I did was I actually ran the 1/0 under the car and the rcas under the side... However, I did take out the seats and everything to install secondskin so I still have some wires under the carpet (remote turn on for eqs) I'd recommending if possible do the lease amount of work when running wire because it's easier to debug if there are any problems or upgrading. With that being said if you're planning on running 4gauge or bigger for your amp you should run it under the car... it's very, very cool :-)
  9. #9
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    37
    4,234
    Quote Originally Posted by johnecon2001
    i disagree. i think you would have the risk of faliure if it was under the carpet because of people steppin on it. pull the rails and push it just under the carpet.j how many people step on the carpet right inside the door? most the time the carpet there is almost vertical making it impossible to step on. and as for breaking clips. . . learn how to take them out correctly. even if you decide to pull the carpet, you still have to take off the rails to get the carpet either out from under it or put it back.
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
  10. #10
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    35
    2,811
    I don't have any side rails, and if your wire gets cut, etc when people step on it, then the insulation is crap.
  11. #11
    diminishedpower's Avatar
    diminishedpower is offline I Like Chicken
    Mar 2004
    Iowa
    933
    yeah i just take rails off and push it down into the carpet a ways, and liek on my taures it has wire gaurds alread at the side were other power is being ran so i unhooked those and put my 0/1 gauge under the gaurd(yes it actually fitted) and its just as safe as anyone runnign it under the the middle of the carpet and less time(and ive never broke a clip yet, knock on wood)
    05 Scion tC
    Subs = 15 inch power hx2 in 3.5 cu/ft at 32 hz
    Sub amp = Cadance ZRS-9
    FOR SALE:
    Ford BNIB 240 amp alt, only 200 shipped
    Refs: T9X, spoonraker
  12. #12
    OLD_SCHOOL's Avatar
    OLD_SCHOOL is offline CarAudio.com Elite
    Aug 2004
    Buford, Ga. Metro ATL
    711
    i pull the rails and push under the carpet as far as i can... unles i am sound proofing the car then i am pulling the carpet and seats and everything else any way might was well run it then... have fun with maintance when you run it like that if you have to ever do any cause guess what you gotta pull it all
    dodge dakota 2003 quad cab
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    6.5 boston comps in the door ( maybe focal soon or ID)
    2 adire tempest 8 ft^3 @23hz
    1 hifonics bxD 1500
    1/0 power and stinger blocks terminals
    AIM Id traumanurse06 add me
    http://www.sounddomain.com/memberpage/681937/1 just set ti up so it is kinda lame
  13. #13
    Einzee's Avatar
    Einzee is offline Service Professional
    Aug 2004
    Norwalk, CA
    44
    344
    4 Post(s)
    [QUOTE=its better than some people i know who ran thier wires under the car onto the frame b/c they thought it was a much safer way. i dont think having your muffler burn through your power wire and maybe a spark to your gas tank is safe lol.[/QUOTE]
    Uh, have you ever heard of zip ties? Of course this layout isn't suitable for every application. A little common sense goes a long way.
    Stupid questions make more sense than stupid mistakes!
    It is best to remain silent and be thought of as stupid, rather than opening your mouth and removing all possible doubt!
    Quote Originally Posted by Twistid View Post
    Try taking the positive wire from your battery and run it to the engine block, see if that should fix things...
    Quote Originally Posted by PaulD View Post
    THE FUSE AT OR NEAR THE AMP PROTECTS THE AMP. WIRES DO NOT NEED "PROTECTING" WITH A FUSE SINCE THEY ARE NOT POWER PRODUCING DEVICES.
    Quote Originally Posted by shake this View Post
    Which one sounds better (short small diameter or long large diameter)?
  14. #14
    jb2xx's Avatar
    Sep 2004
    Los Angeles, CA
    99
    Icon14 Re: side rails Vs under carpet
    Wires went under the carpet. Install guy at the shop was pretty cool. He didn't recomend the side rails since they can get easily damaged if people step on them.
    2004 Honda Civic LX
    Alpine CDA-9830
    Kicker KX400.1
    RF Wiring
    Big 3 Upgrade
  15. #15
    ANeonRider's Avatar
    Aug 2004
    Saskatoon, SK, CAN
    35
    2,811
    Haha, that logic is kinda faulty, lol, considering all the factory wiring that is run to the rear goes through the side rails.
  1. type of carpet
    By carguy in forum General Discussion
    Last Post: 09-08-2002, 11:48 AM
  2. Building a BOX! Need Carpet!
    By JLAudioEXTREME in forum Subwoofers
    Last Post: 08-16-2002, 06:58 AM
  3. Side effects of a big alternator?
    By RcRacerDrew in forum Amplifiers
    Last Post: 08-02-2002, 12:37 AM
  4. Carpet application help...anyone?
    By XSNOIZ in forum General Discussion
    Last Post: 07-25-2002, 09:37 PM
  5. local sources for carpet?
    By maylar in forum Subwoofers
    Last Post: 02-25-2002, 10:30 AM
